No gas mileage difference after trying these mods
Discussion in '4 Cylinder' started by chaz150, Apr 5, 2022.
  1. Apr 5, 2022 at 3:27 PM
    chaz150
    chaz150 [OP] New Member
    Bob
    2014 Toyota Tacoma 4 dr v6 4x4
    I have a 2014 Toyota Tacoma 4dr, V6. Trying to improve gas mileage I put in a K&N Air Filter and a box I plugged into the electrical system. Not really noticing a differance. Should I get rid of them and go back to stock?
  2. Apr 5, 2022 at 4:17 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Yes, it's junk that will damage your engine.
  3. Apr 5, 2022 at 4:54 PM
    chaz150
    Bob
    Thank you very much, coming off tomorrow
  4. Apr 12, 2022 at 2:32 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    LCE header is about the only thing I'd add to this engine. Get yourself all synthetic driveline fluids as well.
    AxisCab likes this.
  5. Apr 12, 2022 at 2:38 PM
    chaz150
    Bob
    Thank you
  6. Apr 12, 2022 at 2:40 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    A box? Wtf is that? Best way to get better mileage is remove all unneeded weight. Run original tire size. Make sure tires psi are set to door jam numbers. Drive like a grandma and stay under 70mph on the highway. Oh and wait for summer so you get summer blend and air is less dense.
    AxisCab, TRD-ED, BuddyS and 2 others like this.
  7. Apr 12, 2022 at 2:42 PM
    chaz150
    Bob
    Thank you
  8. Apr 12, 2022 at 2:46 PM
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Something I recently learned is that there is actually some validity to faster acceleration as it decreases the resistance of the incoming air having to pass through a smaller throttle opening (seriously). All other points are valid. I think my truck has reached 70 mp/h about 10 times in the last 3 years. Speed limits are slower here, which I am fine with.
  9. Apr 12, 2022 at 2:48 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you read the K&N literature carefully their air filters improve HP by a marginal amount. If you're running 6000 rpm. They might add 2-3 mph to the top end for the guys building their own dirt track race cars. But for the average consumer they do very little.
    There is some debate about how well they actually filter the air. For normal driving I don't think they are harmful. But if you drive off road a lot in dusty conditions, they are probably not a good idea. Their biggest advantage is that you can clean and replace the same filter. Long term you should save some money over buying disposable filters.
    I bought one over 20 years ago. The truck I had at the time took a $30 air filter. This when most were $5. The K&N was $40ish and that is the only filter I ever bought for the truck. It didn't help or hurt anything. It was still in the truck when I sold it and I never went back to them.
    wilcam47, SR-71A and DGXR like this.
  10. Apr 12, 2022 at 2:50 PM
    y=mx+b
    y=mx+b Station Wagon
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    Anything that is not a completely stock truck is going to get worse MPG
  11. Apr 12, 2022 at 2:51 PM
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
  12. Apr 12, 2022 at 2:58 PM
    JayRolla
    Colorado Springs
    That's why making sure to change oil regularly helps especially with crappy filters.
  13. Apr 14, 2022 at 8:28 AM
    JayRolla
    Colorado Springs
    I hit 85mph daily. Lol
  14. Apr 14, 2022 at 8:55 AM
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Slow is the new fast. Driving the speed limit is the ultimate luxury for me for many reasons.
    AmherstAndy, JakeSouliere and wi_taco like this.
  15. Apr 14, 2022 at 9:06 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    100% remove whatever electronic gizmo you put on there, it's snake oil and could damage your truck. K&N filters for a 1GRFE won't give any realized performance difference. Just having a clean, well-maintained air filter in general is best performance.
    I've studied my own MPG for about 2 years now logging every tank in my own spreadsheet. For me (and backed up by commentary in other MPG threads), here is the recipe for best fuel economy:
    • Keep speeds at or below 70mph. Faster speeds are guaranteed to lose economy.
    • Use cruise control whenever possible/reasonable.
    • Synthetic fluids in the driveline.
    • Tire pressure: do a chalk test and be sure your tires are kept at the correct pressures.
    • Choose lighter tires with more road-biased tread patterns.
    • Ambient temperatures: Here in Wisconsin we get temps below 32°F about 3-4 months a year. During those times nothing I do makes it better and I lose 3-4 MPGs. Drive less in cold temps if possible.
    • Carry less cargo weight.
  16. Apr 14, 2022 at 9:40 AM
    JayRolla
    Colorado Springs
    I agree with everything other than chalk test. Also carry less cargo should be on top the list and using correct engine oil weight.
    As for chalk test to get a good flat contact you generally run lower psi that lowers fuel economy. You would rather run door jam psi or even max sidewall pressure to get best mileage.
    SR-71A likes this.
  17. Apr 14, 2022 at 9:58 AM
    eon_blue
    Azusa, CA
    keep it well maintained and bone stock (no added weight) and you'll get as good MPG as is possible with a little truck. Tons of snake oil products out there that make a killing convincing people they'll see MPG improvement because the placebo effect is strong. Same with 'performance' parts.
    If you're running heavy D or E rated all terrain tires, ditch them for some stock size highway tires and that will definitely make a difference.
    Woofer2609 likes this.
  18. Apr 18, 2022 at 7:32 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    One other item....ceramic spray coating of the vehicle exterior. I really like the Turtle Wax Hybrid product, since you can also use it on plastics.
    https://www.turtlewax.com/products/hybrid-solutions-ceramic-wax-spray-coating-16-fl-oz
    I use it on the entire front end of the vehicle, including the headlights, but not on the windshield.
  19. Apr 18, 2022 at 1:36 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    You could also run lighter aftermarket wheels to gain a tiny bit more efficiency, but those wheels are probably going to cost you, so... meh.
  20. Apr 18, 2022 at 1:54 PM
    AgentCovert
    AgentCovert Well-Known Member
    22 SR5 DCSB 2.7L
    Return back to the stock air box..but remove the 2nd carbon / charcoal filter that is is riveted in with the plastic rivets in the top lid of the factory air box to greatly improve air flow if you don't have to pass a vehicle inspection..
    Otterstuff likes this.
