No grease zerks after ujoint recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hornedfrog53, Jan 30, 2018.
  1. Jan 30, 2018 at 8:05 AM
    Hornedfrog53
    Hornedfrog53 [OP] Well-Known Member
    2020 TRD PRO
    ok so while my Tacoma was getting the leaf spring recall done about a month ago they replaced my front and rear ujoints as some sort of warranty enhancement. I now have no grease zerks. The mid zerks is still there I just regreased it. I have done this before and had no issue finding them. They are no longer there. I turned the shaft and felt every little corner. Is this a new model that’s “greased for life”?
  2. Jan 30, 2018 at 8:06 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Zerk not Zert.
  3. Jan 30, 2018 at 8:07 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Zerk not Zirk :thumbsup:
  4. Jan 30, 2018 at 8:09 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes; seems "zerk" fittings have disappeared from some 3rd gens. YMMV
  5. Jan 30, 2018 at 8:14 AM
    Hornedfrog53
    2020 TRD PRO
    Fixed to zerks haha
  6. Jan 30, 2018 at 8:17 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    That sucks, i'd not be too pleased.
  7. Jan 30, 2018 at 8:25 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    The new trend, use then replace when they fail.
  8. Jan 30, 2018 at 6:03 PM
    bdbrown
    bdbrown Well-Known Member
    Benjamin
    Canada
    '06 SWB DCSB MT
    lucky rocketship underpants
    What's the expected lifespan of an unservicable u-joint?
    Had a u-joint fail while away from tools/shop so took it into a toyota dealership in NW ontario, bill was close to $300cad to replace a single joint... Burnt that bridge pretty good, but 2.5 hours for a toyota tech in a toyota garage to do a job that took me 45 minutes with carpenters tool first try, I was pissed, and told them so.. I hope this was just miserable people trying to make a buck, but I'd be concerned if they're trying to make the drivelines unserviceable..
    Might be worth noting that they did replace it with a normal u-joint, with a zerk.
  9. Jan 30, 2018 at 6:22 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    They were free and replaced for free. If he wanted the greasable u-joints, he could do it himself. Non greasable u-joints are very common these days.
    That said, if the dealer just decided to replace parts which I didn't authorize him to replace, I wouldn't be pleased.
  10. Jan 30, 2018 at 6:24 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    This isn’t a new trend. It’s a sealed joint. Some people prefer them as they tend to keep grease and water out better. I prefer zerks on OE quality joints. You can always drill a hole in the cap and screw a fitting in.
  11. Jan 30, 2018 at 11:29 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    05Taco4x4 likes this.
  12. Jan 30, 2018 at 11:32 PM
    bdbrown
    Benjamin
    Canada
    '06 SWB DCSB MT
    What's your maintenance schedule for them, just swap 'em when they're toast? How long do they last?
  13. Jan 31, 2018 at 2:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  14. Jan 31, 2018 at 4:55 AM
    taco2010trd
    Tampa, Florida
    Disposable
  15. Jan 31, 2018 at 5:16 AM
    badger
    badger Well-Known Member
    07 SR5
    One of many reasons why I just don't let those monkeys touch my truck. They are always finding creative ways to short you. If your truck came equipped with greasable joints, you should expect to get the same. If they are going to make a substitution, they need to get your approval. I would take it back to them and get the right joints.
    One great part of greasing ujoints is that it gives you the chance every 5,000 -10,000 miles to detect a bearing going bad. I have carried a ujoint press and spare ujoints with me since the 70's, because I spend a lot of time in the back country. So far I have never had to replace one, but I have helped many others! I can't tell you how many were just filled with dry dust. My truck is coming up on 168,000 miles and still has the original joints,...all are still good as of 160,000. I'll be back under there in a week or so because my center bearing is toast.
  16. Jan 31, 2018 at 5:41 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Non zerk joints are preferred by some because they are stronger; they are solid steel. Zerk joints have grease passages to all four bearing cups which makes them more susceptible to failure under extreme loading.
  17. Jan 31, 2018 at 5:51 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That doesn't make any sense. None at all.
    With grease fittings you can maintain them and they will last a very long time. Without fresh grease the old grease will degrade or get washed out from water and the joint will fail sooner than later.
    taco2010trd[QUOTED] likes this.
  18. Jan 31, 2018 at 5:58 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    No. Not even close. It sounds good in theory, but in the real world it isn't going to happen. If you are loading a universal joint with grease fittings to the point that it breaks then you are doing it wrong.
    If loading that much you will probably rip out the differential first, many have done just that.
  19. Jan 31, 2018 at 6:37 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
  20. Jan 31, 2018 at 10:54 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Primarily, I'm too lazy to grease them. I also prefer non-greaseable BJ's. I have cross-threaded zerk fittings before and had one break off while off-roading, which I will admit is highly unlikely to happen again, but it can happen - I don't drive over thick bushes as much as I used to.
    From my experience, the non-greaseable last as long as the greaseable. I usually replace every 100K as preventive maintenance anyways.
    bdbrown likes this.
