No gumption from my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mander, Jan 21, 2014.
  1. Jan 21, 2014 at 4:45 PM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    98 Tacoma Limited 3.4
    hi i have a 98 tacoma and it is has no get up and go just wondering if there is some things i could do to improve this without digging too deep. it does have over 250,000 miles and im wondering if that could be part of the problem. also the previous owner removed the catalytic converter and i was also wondering if that could be the issue. thanks and anything will help.
  2. Jan 21, 2014 at 5:10 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    its a truck. they're not meant to get up and go. they're meant to get up and haul stuff or tow things.
    have you had a tune up? spark plugs, oil change, transmission drain, throttle body cleaning and all that good stuff? if not, with that many miles it probably has quite a carbon, dirt, and grime buildup. you can also try a seafoam cleanse, but use cautiously some claim it did more harm than good.
  3. Jan 21, 2014 at 6:46 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Nice, 250k miles? If anything removing the cat would increase the exhaust capability. It may need a tune up. Spark plugs, injector cleaning, fuel filter etc etc.
  4. Jan 21, 2014 at 7:14 PM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    Thanks guys and yes i change the oil on regular intervals and as far as the other stuff ive only done new spark plugs. Ive used seafoam on it before. Perhaps i will try some better plugs and wires and a good quality tune up. Any more suggestions?
  5. Jan 21, 2014 at 7:15 PM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    And yes it is currently sitting at 253 thousand miles
  6. Jan 21, 2014 at 7:17 PM
    The6pharaohs
    The6pharaohs WTF just happened?
    Wil
    Eagle Mountain Utah
    2017 DCSB Offroad with JBL premium tech package
    Upgraded from 2012 DCSB TRD Offroad Entune JBL w/nav
    Full fluid flush and tune up the spark plugs
  7. Jan 21, 2014 at 7:19 PM
    Silence9
    Alberta, Canada
    Brakes? It's possible they're not functioning correctly. Fluids couldn't hurt either.
  8. Jan 21, 2014 at 7:23 PM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    What spark plugs do you guys recommend? Also on the fluids should i go with toyota brand or some other brand (s)
  9. Jan 21, 2014 at 8:04 PM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    Also i read about a valve clearance adjustment how often have you heard about these needing to be done or if they needed to be done at all?
  10. Jan 22, 2014 at 10:12 AM
    Silence9
    Alberta, Canada
  11. Jan 27, 2014 at 5:14 PM
    Blyth
    Blyth Member
    Which engine do you have in it? I have a 97 with a 3.4 V6, 5 speed that goes like snot with 31's on it.
  12. Jan 27, 2014 at 5:47 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    How long has it been since you changed the fuel filter? A plugged fuel filter can restrict fuel flow and greatly reduce power.
  13. Feb 1, 2014 at 6:08 PM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    Its a 98 v6 3.4 liter 5 spd with 18s on it and no i haven changed the fuel filter in a while ill prolly do that very soon
  14. Feb 1, 2014 at 6:14 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    What size tires does it have, is truck throwing a code.
  15. Feb 1, 2014 at 6:26 PM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    It has 18 inch rims with 245s on it and ya it has a code for catalytic converter only because there isn one its straight piped all the way back
  16. Feb 2, 2014 at 3:52 AM
    toyodajeff
    jeff
    06 reg cab sr5
  17. Feb 2, 2014 at 5:48 AM
    Mander
    Mander [OP] Member
    Brian
    Wyoming
    Thanks man ive been looking for something like that gonna pick that up soon as well
