No hassle dealerships for TSB 0062-18
Discussion in 'Southern California' started by Ljid13, Aug 15, 2018.
  1. Aug 15, 2018 at 4:45 PM
    Ljid13
    Ljid13 [OP] Well-Known Member
    2018 TRDOR 4x4
    any local dudes get this TSB applied without any issues from the dealership? Which dealership did you go to?
  2. Aug 15, 2018 at 4:48 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    I got the tsb applied at Manhattan Beach, service advisor was hesitant but I got to go on a test drive with the tech and he applied it after no real "symptoms"
  3. Aug 15, 2018 at 10:43 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Mossy Toyota in San Diego is doing this no questions asked based on reports on TW.
    Ferns and sdsurfer like this.
  4. Aug 19, 2018 at 2:44 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Santa Margarita Toyota.
  5. Aug 20, 2018 at 7:55 PM
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    Toyota of Glendale applied the 0058. They agreed with the “symptoms” of the vehicle and applied the update.
  6. Aug 20, 2018 at 8:03 PM
    Volksparts
    Volksparts AKA The Un"Official" Meso Taco
    Dave
    San Diego
    2017 Taco Runner
    Alfonso helped me out with my tsb update at Mossy. He took really good care of my truck as always
    Norsemanvike[QUOTED] likes this.
  7. Aug 21, 2018 at 11:14 AM
    NormanPerez
    NormanPerez Well-Known Member
    Norman
    Rolling Hills Estates
    2018 TRD Off-Road
    stock a fawk!
    I bought my truck in January. 18’ OR. I don’t seem to have the stumble. Or how would I check for that?
  8. Aug 21, 2018 at 1:52 PM
    Norsemanvike
    Escondido, CA
    From a complete stop, hit the gas fairly hard or stiff if you will. your truck will surge, pause while it hunts for a gear for a second or two, then rev to high rpms to get up to speed and then start settling down. Tell your dealer that from a stop, you hit the gas and your truck will surge/pause/rev high rpms before it actually gets going. After the TSB is done, when you hit the gas, your truck will shove you into the back of your seat immediately like it should, so make sure you're prepared when you test the TSB when it's done.
  9. Aug 21, 2018 at 3:09 PM
    NormanPerez
    Norman
    2018 TRD Off-Road
    stock a fawk!
    I’ll try it out and see if my local dealer will do it hassle free. Near Torrance otherwise i’ll Go to manhattan beach
  10. Aug 21, 2018 at 7:38 PM
    NormanPerez
    Norman
    2018 TRD Off-Road
    stock a fawk!
    Called them up and they told me they didn’t see any recal for my vehicle but to bring it in. It lags but not much of a surge. But it definitely doesn’t throw me in the seat. We’ll see tomorrow.
  11. Aug 21, 2018 at 9:27 PM
    Norsemanvike
    Escondido, CA
    Recalls and TSBs are two different things. This TSB in PDF form is posted several times in this thread, print it out and take it with you.
  12. Aug 21, 2018 at 9:30 PM
    Bishop84
    Bishop84 Well-Known Member
    They aren't intended for customers to supply and demand to be completed. Toyota doesn't want warranty work to be performed simply because everyone is doing it. (All manufacturers)
    If you want the TSB to be performed, make sure you complaint is as exactly described in the TSB. This way the dealership and Toyota is happy, and you get what you want.
    So describe as the TSB says. "It delays on the highway" "It surges" etc.. You'll be fine.
  13. Aug 22, 2018 at 3:59 AM
    Hogan1966
    Hogan1966 Well-Known Member
    Kevin
    Loveland, OH
    2021 DCSB TRD OR - Army Green
    Blackout package - planned: black bed logos, black wheel vinyls, front seat window tint, tires.
    I'm going to test this today, but based on dealers not being able to "reproduce symptoms", does it happen every time? I honestly don't know if I've ever hammered down on the throttle like that since I've had it, but I'll give it a shot.
  14. Aug 22, 2018 at 12:09 PM
    NormanPerez
    Norman
    2018 TRD Off-Road
    stock a fawk!
    Well DCH Toyota of Torrance did it. Just told them “stumble”, “Surge”, and “standstill throttle” and they did it. Took them all of three effing’ hours but they did it. It’s not throw you on your seat instant response. But it’s smoother, stays in the revs longer, and shifts way better. Drops a gear, pulls longer and smoothly shifts out of it. Overall I like it.
    Norsemanvike likes this.
  15. Aug 23, 2018 at 3:26 PM
    Norsemanvike
    Escondido, CA
    A friend took his to Temecula and they stated that they couldn't replicate the stumble, so I'm sending him this thread and to a different dealership for the TSB.
  16. Aug 23, 2018 at 3:46 PM
    NormanPerez
    Norman
    2018 TRD Off-Road
    stock a fawk!
    I noticed that it even improved when you’re rolling at a slow speed not just from a dead stop
  17. Aug 25, 2018 at 12:27 PM
    Ferns
    Ferns Member
    San Diego, CA
    2018 MGM Off Road
    How long did it take you at Mossy? I got push back from Toyota of El Cajon and they wanted to keep vehicle for an entire weekday
  18. Aug 28, 2018 at 1:40 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Toyota of Redlands did mine
  19. Aug 28, 2018 at 1:50 AM
    burnt_taco
    burnt_taco Well-Known Member
    3rd Gen Tacoma Limited 4x4
    Toyota of Chula Vista did mine no questions asked.
  20. Aug 29, 2018 at 9:26 AM
    Sleevez
    Sleevez Well-Known Member
    LA / Toronto
    2017 SW TRDPro, 2000 PinkTaco
    Anyone got this done for their manual trans 6mt?
    derf77 likes this.
