No Hazard or Turn Signals
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rico, Sep 21, 2010.
  1. Sep 21, 2010 at 3:19 PM
    Rico
    Rico [OP] Member
    Blinkers/signals worked fine up until I hit the hazard light button on dash. Depressed hazard light button and still no turn signals or Hazard lights inside or out side at all.
    All fuses are good and nothing smells burnt or fried. When I press the hazard light button I hear the relay engage near the fuse box but I still zero flashing lights anywhere not even in the dash.
    This happened about two years ago, one morning I press the hazard button and it worked and so did the turn signals. Very strange!
    Could this be a bad relay or hazard switch (button)? My guess is the turn signals are on the same relay circuit as the hazards.
  2. Sep 21, 2010 at 8:06 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Take the dash trim off and check the plug connection for the hazards. I found out (the hard way) that if the hazard switch is disconnected the turn signals don't work at all while driving down the road with a nice new stereo jammin'.
    ZeusandPepsi likes this.
  3. Sep 21, 2010 at 8:38 PM
    Rico
    Rico [OP] Member
    I suspect it the hazard switch also. I will take it out again and check the contacts.
  4. Sep 21, 2010 at 9:03 PM
    Rico
    Rico [OP] Member
    Ahh Think I found the problem but I need someone to test. The hazard switch has a little light bulb that easily screws in or out when it needs to be replaced. If the bulb is burned, it leaves the circuit open. I think this bulb completes the turn signal and hazard circuit. Can someone confirm by removing the light and see what happens or better yet check the wiring schematic for a 2000 Tacoma 4x4 SR5.
  5. Sep 22, 2010 at 6:06 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Nope - that can't be it.
    The illumination bulb in the hazard switch is on an entirely different circuit (same as your dashboard lighting).
    If you haven't done so already, check the 15A HORN fuse.
  6. Sep 22, 2010 at 7:58 AM
    Rico
    Rico [OP] Member
    15A horn fuse checked and is good. Horn works fine. However two weeks ago it didn't work either then one day I had to slam on my breaks and hit the horn hard and it worked.????
    Does the ECU control the Horn,Turn sig and Hazards circuits at all?
  7. Sep 22, 2010 at 9:26 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    The ECM has nothing to do with any of these functions.
    The line controlled by the hazard switch has the 15A HORN fuse as its power source.
    Are all four turn signal lamps working?
    The hazard switch (and / or wiring around it) is probably the #1 suspect. I'd rank the flasher #2.
    However, your report of the horn weirdness suggests you have a more general wiring fault issue somewhere in your dash area.
  8. Sep 22, 2010 at 5:44 PM
    Rico
    Rico [OP] Member
    Problem Solved:
    Flasher was bad. I opened the casing which was easy to do and I saw one end of a solder joint was a little burned. The solder joint looked ok at first glance but under close examination I could see the solder was not bonding to the metal component joint. I remove,sanded, cleaned the component and soldered back on with a little flux. Good as new.
  9. Oct 12, 2010 at 9:44 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    you have just fixed my hazards problem! thanks!:D
  10. Oct 14, 2010 at 8:10 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Glad to be of service ... :D
