No heat after Radiator Flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Labman, Nov 6, 2015.
  1. Dec 6, 2015 at 4:06 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Air in the core #5.
  2. Dec 8, 2015 at 4:53 PM
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    Il give this a try this weekend and let ya know what happens. Thanks for the help !!!!
  3. Dec 15, 2015 at 9:49 AM
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    Ok I put a small hole in the hose, and let it bleed, little to no air came out of the hose, I revved the engine and it it shot a steady stream out of the hole, inlet hose is hot the outlet hose luke warm. No change in heat coming out of the vent, so I'm stumped.
    Thoughts ?
  4. Dec 15, 2015 at 9:52 AM
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    Does it take your coolant a long time to get to operating temp?
    doyouevenprerun likes this.
  5. Dec 15, 2015 at 9:54 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    Have you tried changing your thermostat like a couple people have said?
    shakerhood likes this.
  6. Dec 15, 2015 at 9:56 AM
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    No, its pretty normal 5 minutes or so operating temp is normal.....
  7. Dec 15, 2015 at 10:09 AM
    Alfred
    Alfred
    California
    So your temperature gauge is near the middle?
  8. Dec 15, 2015 at 1:57 PM
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    Well have you?
    Also, at full op temp do your hoses get nice and hot?
  9. Dec 15, 2015 at 2:30 PM
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    No that's next on the list,,,do have to drain the radiator to do that ? The last Tstat I changed was a small block Chevy.....
  10. Dec 15, 2015 at 2:41 PM
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
  11. Dec 15, 2015 at 4:12 PM
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    The temp gauge sits just a hair under half way, yes the hoses are hot .
  12. Dec 15, 2015 at 6:19 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Sounds like you have a lack of coolant flow through the heater core - either due to blockage internally in the core, damage to the water pump impeller, or incorrect plumbing of the heater hoses, which IIRC, you said you had checked previously.
    Has any "stop leak" ever been used in the system?
  13. Dec 15, 2015 at 8:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have to say it does sound like the core is blocked if the hose going in is hot and the hose going out is cold...
  14. Dec 16, 2015 at 1:14 AM
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    No stop leak has been used, I guess I'm gonna have to replace the core. Thanks for all the help and advice.
  15. Dec 16, 2015 at 5:16 PM
    #35
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    try flushing and back flushing the core one more time before you go and start tearing the dash apart
    landphil likes this.
  16. Dec 16, 2015 at 10:15 PM
    #36
    landphil
    BC, Canada
    Tundra 5.7 mod
    Yup - I sure would.
  17. Jan 11, 2016 at 4:50 PM
    #37
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    I have a new thermostat on my bench...haven't had time to change it but will this weekend...I have an OBD2/ doggle and the app on my phone forgot I had it. So I hooked it up and drove home today...According to the APP my Engine temp never got higher than 87 degrees which is the temp coming out of my Vents. The truck doesn't over heat and the needle is running in the normal range...not quite half way up....also my top radiator hose is Hose is the bottom is ice cold. So I'm assuming the T stat is stuck half way open. I'll update this weekend...
  18. Jan 11, 2016 at 5:39 PM
    #38
    landphil
    BC, Canada
    Tundra 5.7 mod
    Is your App reading 87degrees Celcius by any chance? I find it strange that the temperature gauge is sitting in the middle once warmed up, and you should have had a P0128 code and a check engine light on by now if it never warms over 87 degrees Fahrenheit.
    The bottom rad hose being ice cold indicates to me that the thermostat is indeed shut.
  19. Jan 11, 2016 at 5:43 PM
    #39
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not that it shouldn't be higher, but just curious where do you live and how far do you drive to-from work?
  20. Jan 12, 2016 at 2:58 PM
    #40
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    70 miles round trip daily on the Interstate, I live in Iowa 4 degrees out today. What is the normal operating Temp. supposed to be anyone no ?
