No heat after Radiator Flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Labman, Nov 6, 2015.
  1. Jan 12, 2016 at 3:04 PM
    #41
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Yeah you're warming it enough on that drive for sure.
    Not sure but I think the T-stat is 185F
  2. Jan 12, 2016 at 3:57 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Mine usually runs about 189 to 190 degrees F as read by Ultragauge.
  3. Jan 23, 2016 at 7:47 AM
    #43
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    Well I changed out the T stat ..No change, no heat...Can anyone recommend what to flush the heater core with...I just used the garden hose last time and plain water, should I disconnect the hoses to the core and fill it with a cleaner and let sit and for 30 minutes and re flush ??
    Thanks
    Steve-
  4. Jan 23, 2016 at 8:32 AM
    #44
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
  5. Jan 23, 2016 at 8:34 AM
    #45
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    Where is that Located ?
  6. Jan 23, 2016 at 9:03 AM
    #46
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    Does anyone know where the blend door servo is loacated ? 2007 Tacoma...?
  7. Jan 23, 2016 at 9:20 AM
    #47
    billybob50
    Bob
  8. Jan 23, 2016 at 9:28 AM
    #48
    Labman
    Labman [OP] Member
    2007 Tacoma SR5
    None
    Got it..Thanks...as far as the control valve goes from what I have learned there is not a control valve, coolant circulates constantly through the core and the blend door either opens or closes for Heat or A/C so I'm gonna verify it's opening all the way...
  9. Jan 23, 2016 at 11:13 AM
    #49
    billybob50
    Bob
  10. Jan 23, 2016 at 10:17 PM
    #50
    Jimmyh
    SC
    2012 Prerunner SR5
    What you are looking for is the " Air Mix Control Servomotor ". Accessable from the passenger side floor area.
    Where the servos are located:
    How to test the servos:
    http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/04600910.pdf
  11. Jan 23, 2016 at 10:36 PM
    #51
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Correct, there is no water control valve in these systems. The heater core should be getting full flow at all times the engine is running.
  12. Jan 25, 2016 at 1:06 PM
    #52
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    Disconnect both heater core hoses. And flush water in one end. Then back flush by doing the same thing through the other end. Do it a couple times. Then hook it back up and bleed the system like I mentioned earlier in this thread. You may have to bleed it a couple times
  13. Jan 25, 2016 at 11:46 PM
    #53
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    This. ^ Let the water run during each front and back flush. Last time I had to do this (on a Dodge) I ran the discharge hose to a clean 5 gallon bucket to see what came out. Turns out a mechanic had used too much silicone somewhere along the line. Took three tries, probably 20 gallons each time I flushed, on different days to finally get the cooling system cleared of that mess.
