No heat at Idle.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brent Waldman, Oct 22, 2015.
  1. Oct 22, 2015 at 10:30 PM
    Brent Waldman
    Brent Waldman [OP] Active Member
    Brent
    Grand Junction Colorado
    2005 Tacoma TRD Off Road
    2.5 in lift
    I dont know if this is a common problem but here it goes. Above 1000 rpm I get great heat out of the heater. However at an idle its a different situation. Antifreeze levels are gook and the heater supply and return lines are not kinked. Heater control valve works fine. As soon as i raise the rpm I develop heat again. Needless to say I'm stumped. Any help would be great.
    2005 TRD Off Road
  2. Oct 22, 2015 at 10:30 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Reported for racial slur.
    Also, bump.
    12TRDTacoma and Lomez like this.
  3. Oct 22, 2015 at 10:33 PM
    Brent Waldman
    Brent
    2.5 in lift
  4. Oct 22, 2015 at 10:39 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Is this only at startup? I always have this problem. Works fine after I run it for at least 30 min. It always will feel either colder or warmer when you're moving.
    x2 ?
  5. Oct 22, 2015 at 10:39 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Get used to that guy haha. About half of his posts are kinda useless but amusing. As are about 90% of the people around here. I'd start with checking out the thermostat. Had the exact same problem last winter with mine. And that did the trick :)
    Edit: Don't know if you meant thermostat by heater control valve. If you did then best of luck fixing the problem, heat can be a real PITA sometimes.
  6. Oct 22, 2015 at 10:41 PM
    PapaBear
    Austin
    SIN CITY
    Yours is an 03 2.7, his is an 05 4.0, how are they similar?
    KN likes this.
  7. Oct 22, 2015 at 10:42 PM
    RustyVT
    Vermont
    They both have thermostats don't they.....
  8. Oct 22, 2015 at 10:43 PM
    T4RFTMFW
    And you think my posts are silly and useless?!
    jberry813 and PapaBear like this.
  9. Oct 22, 2015 at 10:43 PM
    Brent Waldman
    Brent
    2.5 in lift
    I'll check the thermostat haven't done that yet. It does it even after driving for an hour doesn't seem to be a start up issue.
  10. Oct 22, 2015 at 10:45 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Silly...yes. Useless...no.
    No homo
    DoorDing and T4RFTMFW[QUOTED] like this.
  11. Oct 22, 2015 at 10:46 PM
    RustyVT
    Vermont
    What he said, I guess it wasn't useless after all. You did bump it :p Sorry.
  12. Oct 22, 2015 at 10:47 PM
    PapaBear
    Austin
    SIN CITY
    One has substantially more heat coming from it. We are talking about 2 more cylinders pumping away.
  13. Oct 22, 2015 at 10:51 PM
    PapaBear
    Austin
    SIN CITY
    You also live in Grand Junction Colorado... Its 47 F. with 97% humidity right now. Your engine is trying...;)
  14. Oct 22, 2015 at 11:04 PM
    RustyVT
    Vermont
    Yeah good point, never know though. Worth a shot, don't know how difficult the 4.0 is to work on. But I'd assume a thermostat is probably one of the easier things. Unless they buried it somewhere that's a pain to get to. I know diddly squat about the 2nd gens. Gonna have to browse around and learn a little.
  15. Oct 22, 2015 at 11:13 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    sounds more like air in the system. park it heading uphill or on ramps. open rad cap, start engine run till it burps out the radiator.
    PapaBear likes this.
  16. Oct 22, 2015 at 11:25 PM
    Brent Waldman
    Brent
    2.5 in lift
    Belt is new and the temp has never been above the normal range. Water pump is original so I suppose after 178k miles it could be straining at idle. Thanks for all the input everyone.
  17. Oct 23, 2015 at 5:03 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    a. weak water pump
    b. partially clogged heater core
    c. air in system - mentioned above
  18. Oct 23, 2015 at 7:42 PM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
  19. Oct 23, 2015 at 8:00 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Have you ever replaced your cabin filter? It could help...
    I have the 2.7 and on cold mornings here in california (below 40 *F, rare but it does happen) it takes awhile before I starting feeling heat through the vents. It might just be normal...
  20. Oct 23, 2015 at 11:26 PM
    Brent Waldman
    Brent
    2.5 in lift
    Update and not what I wanted to hear. Bad head gasket, upon startup of the truck the cooling system immediately builds pressure. The mechanic that diagnosed the issue has seen it before. The head gasket is compromised just enough that combustion gasses are making it past the head gasket into the cooling system creating an air pocket. When the truck is at an idle the water pump is unable to overcome the air pocket being generated. As soon as the RPM are raised the water pump is able to push coolant and overcome the air pocket. My mechanic did state this leak is very minor but it doesn't take much to create the problem. The truck does not burn antifreeze or have the usual markers of a head gasket issue. (Swinging temps, low compression) He did perform a compression check and everything looked fine. It wasn't until a bleed down compression test was performed the issue was found. Cylinder 5 seems to be the issue.
