No heat on my feet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by urbanplanner, Dec 8, 2011.
  1. Dec 8, 2011 at 8:52 PM
    urbanplanner
    urbanplanner [OP] Active Member
    washington state
    leveling kit HID
    So, how well do your rigs push air to your floor? Mine wants to leak some to the windshield vents and dash vents when set to the floor. It's comes out down low, but is pretty weak. Hot/cold is fine, I'm just dealing with a damper issue, or maybe it's "normal"?
  2. Dec 8, 2011 at 8:58 PM
    islandwheeler
    islandwheeler Member
    Mine is the same. Just no real strength at the bottom. Dash blows like crazy tho.
  3. Dec 8, 2011 at 9:04 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I think there is a TSB out for something to do with the vent direction lever? Look it up.
  4. Dec 8, 2011 at 9:25 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    When I have mine on just the floor it works great and it leaks a little through the other vents but not enough to notice. Check your heater box maby it's got some debri in it
  5. Dec 8, 2011 at 9:27 PM
    htowntaco23
    htowntaco23 Well-Known Member
    Matthew
    Austin, TX
    07 PreRunner SR5
    Carr side steps, Flowmaster 40 series dual exhaust, Spyder projector headlights, black housing LED taillights, 2 10' JL Audio subs, Polk amp, Famous Fabrication hood mount brackets, 2 Rigid Industries Dually LEDs
    I have the same problem so i just turn it on half and half
  6. Dec 9, 2011 at 9:10 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Believe the proper term for the part in question is blend door, and it sounds like its not working
  7. Dec 9, 2011 at 8:53 PM
    urbanplanner
    washington state
    leveling kit HID
    yep, there are several older thread on this that show up on the search. It's about a $1,000, 2 day job at the dealer.
  8. Dec 9, 2011 at 8:58 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Dunno, thought that switching it to the floor vent was supposed to direct air to the windshield, floor and side vents. Kind of like defrost without using the A/C. Didn't know there was a TSB for this. Thought I read it was supposed to work this way. :notsure:
  9. Dec 10, 2011 at 7:34 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    On my blazer i jammed a coat hanger up the vent to open it
  10. Dec 10, 2011 at 7:47 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    Mine has been like this since the day I drove it off the lot.
