no heat with new thermostat
Discussion in '1st Gen. Tacomas (1995-2004)' started by ramsey50, Dec 17, 2010.
  1. Dec 17, 2010 at 7:34 PM
    ramsey50
    ramsey50 [OP] New Member
    TN
    97 2.7l Tacoma
    I have a 97 tacoma with a 2.7l in it.I am having a problem getting heat in the cab.I replaced the thermostat today and coolant levels are good but the radiator on the drivers side stays cool unless you put a piece of card board in front of the radiator.also i get a whiff of antifreeze from time to time.does anybody have any suggestions. thanks
  2. Dec 18, 2010 at 8:10 PM
    2531 Member
    cape cod
    99 4x4 2.7 5spd
    run system with rad cap off for a while with heater on after installing thermostat, to bleed all the air out. Feel the temperature of your heater hoses near the firewall when engine warmed up to normal operating temperature. If both fairly hot, you should get heat, if one hot, one quite a bit cooler, you have a flow problem. That could be a valve not opening, core plugged, weak water pump, for examples. if all that checks out good, then I'd be checking my blend/air door for movement
  3. Dec 19, 2010 at 4:55 PM
    98Tacoma
    98Tacoma Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    like 2531 said run it without the rad cap and turn on the heat full blast sometimes that will push some air pockets out of it. you can also burp the system by lifting the front of the truck up and doing the same thing. hope this helps
  4. Dec 20, 2010 at 3:00 PM
    ramsey50
    TN
    97 2.7l Tacoma
    i tried running it till normal operating temp with the radiator cap off but didnt get any air pockets to come out.on my heater core hoses one of them was quiet a bit cooler than the other so i took my hoses off and ran water through my heater core and there was some brown and milky stuff came out so i will find out tomm if that worked.also how much pressure should the water pump have.to me it seems weak because when you squeeze the radiator hoses and rev the motor it doesnt seem to have a hole lot of pressure. thanks for the tips though
  5. Dec 20, 2010 at 3:04 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    make sure you installed the tstat in the right direction.
  6. Dec 20, 2010 at 3:12 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Was there heat before you F**ked with it?
  7. Dec 20, 2010 at 6:37 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    does you radiator have the same gunk in it to? my dads radiator is like that now and he will have heat on and off because it has restricted flow
  8. Dec 23, 2010 at 11:56 AM
    ramsey50
    TN
    97 2.7l Tacoma
    i have heat now and why would i mess with it if i had heat.but it turns out needing a hole coolant system flushing.i have just had the truck since the end of november and its my first tacoma.is the heat in the tacomas pretty weak i read that on another forum on here.
  9. Dec 23, 2010 at 11:58 AM
    ST77
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    What temp of tstat did you put in?? That will determine how good your heat is... Mine is hotter than hell on full blast!
  10. Dec 23, 2010 at 3:14 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Mu guess is you installed the t stat backwards.
    Flash
  11. Dec 23, 2010 at 6:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    200*F water temps FTW!
