No heat
Discussion in '1st Gen. Tacomas (1995-2004)' started by beener427, Aug 24, 2010.
  1. Aug 24, 2010 at 7:55 PM
    beener427
    beener427 [OP] New Member
    Jim
    Syracuse, Utah
    99 Tacoma SR5
    Lift, 33's
    Cool mornings lately, the temp knob has been on cool all summer, so this morning I tried to turn it to hot and it clicked with about a 1/4'' movement. Moved the temp control valve on the firewall manually to hot and the temp did not change to hot in the vents. The cable does move the temp control valve now, but there is still no heat in the vents. Just cold air always. Antifreeze level is full and always has been. Any suggestions or similar problems? Thank you .
  2. Aug 24, 2010 at 11:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you have a temp gauge? Is the truck getting up to running temps?
  3. Aug 25, 2010 at 4:09 AM
    beener427
    Jim
    Syracuse, Utah
    99 Tacoma SR5
    Lift, 33's
    The temps are normal, not overheating and not staying cool. Temp control valve is working fine also.
  4. Aug 25, 2010 at 4:15 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I had a similiar problem on my 99'. There was a linkage (rod) that had worked itself off under the passenger side dash. It was a real easy fix, although I don't remember for sure what my symptoms where but I do beleive it was the same issue you are having.
  5. Aug 25, 2010 at 9:42 AM
    beener427
    Jim
    Syracuse, Utah
    99 Tacoma SR5
    Lift, 33's
    The linkage is working( if it's the obvious cable at the feet of the passenger ) but I did notice when checking the temp valve I had to drain some antifreeze out of the radiator. When draining, radiator fluid is cool versus the hoses above were still pretty hot. Only cooled down for about ten minutes after trip home. Starting to sound like the thermostat?
  6. Aug 25, 2010 at 10:39 AM
    beener427
    Jim
    Syracuse, Utah
    99 Tacoma SR5
    Lift, 33's
    After thinking more of the linkage, you were correct Rtrn2taco, the connection is broken or come loose somewhere along the cable above. Gotta get into the dash behind the glovebox to see what's up. Thank you both for your help and chiming in when needed.
  7. Aug 25, 2010 at 10:51 AM
    Rtrn2taco
    Philadelphia
    glad I could help, good luck
