no heat
Discussion in '1st Gen. Tacomas (1995-2004)' started by belvoirst13, Dec 7, 2010.
  1. Dec 7, 2010 at 5:16 PM
    belvoirst13
    belvoirst13 [OP] Member
    nc
    01 tacoma
    i have a 01 tacoma and the heat doesnt work it blows air but just cold air i took the air control out and was wandering what the prob could be i believe it is the blend door but can not locate it
  2. Dec 7, 2010 at 5:20 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    have you checked your thermostat?
  3. Dec 7, 2010 at 5:23 PM
    belvoirst13
    nc
    01 tacoma
    i checked it it works fine the wire on the fire wall does move either when i turn it from hot to cold so i was thinking acutator
  4. Dec 7, 2010 at 5:28 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Are both of your heater hoses hot?
  5. Dec 7, 2010 at 5:31 PM
    belvoirst13
    nc
    01 tacoma
  6. Dec 7, 2010 at 7:07 PM
    NelsonTacoma
    Tucson, AZ
    Based on all the info you've given. It doesn't sound like a coolant level problem, doesn't sound like a blower problem, doesn't sound like a heater valve problem. The only thing I can think of at this point is to flush out the heater core? Other than that maybe the temp door in the a/c/heater case is jammed or the control cable came off?
    I tried finding a diagram of the HVAC box on your truck and I can't find one:(.
  7. Dec 7, 2010 at 7:58 PM
    belvoirst13
    nc
    01 tacoma
    i flushed the heater coil and still not hot air and im having the same problem with diagrams
  8. Dec 7, 2010 at 7:59 PM
    belvoirst13
    nc
    01 tacoma
    and as for the control cable i couldnt find one it all look to be electronic behind the control body
  9. Dec 8, 2010 at 8:31 AM
    IKE1000
    IKE1000 New Member
    Isaac
    South Carolina
    93 Taco
    I'm having the same problem with my truck, and was wondering where the heater hoses are located.:confused:
  10. Dec 8, 2010 at 8:36 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The heater hoses run along the firewall and go in behind the glove box.
  11. Dec 8, 2010 at 8:38 AM
    IKE1000
    IKE1000 New Member
    Isaac
    South Carolina
    93 Taco
    Thanks a lot.
  12. Dec 8, 2010 at 8:40 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  13. Dec 8, 2010 at 4:03 PM
    IKE1000
    IKE1000 New Member
    Isaac
    South Carolina
    93 Taco
    Well I found the root of my problem. The previous owner who lived in Florida had bypassed the heater core. When I hooked it back up, I realized why. The Pipe going into the heater core had been deformed somehow, so coolant gushed out from the hose connection when the truck was running. I took off the hose and wedged a socked in there to get it back to a circular form and hooked it up again. worked like a charm. thanks for the help fellas.
