No high beam with h4 harness. Help!
Discussion in 'Lighting' started by Burgess65, Dec 8, 2012.
  1. Dec 8, 2012 at 5:01 PM
    Burgess65
    Burgess65 [OP] Active Member
    Hey guys, so i just purchased the mini ds2 with bixenon harness kit from trfs and have everything hooked up an ready roll. problem is that i have no high beam function. i tried swapping the blue and white wires but still no high beam. anyone have any idea how I should hook up the oem connector to my new harness? Or could it be something else? I would assume the solenoid wires are connected properly as I have matched red to red and black to black. Any suggestions would be great! Thanks!
  2. Dec 8, 2012 at 5:12 PM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    '13 MGM DCSB 4x4 TRD sport, Tow and Entune
    Tonnopro tonneau cover, Weathertech digital fit mats, Magnaflow 18" muffler with black exhaust tip, blacked out badges/emblems, Passport 9500ix, Pop & Lock PL8521, EZdown tailgate mod, 17" KMC XD addicts, 265/70/17 Nitto Terra Grapplers, OME 884 springs, Bilstein 5100's at zero, BHLM, FX-R retrofit, 80mm and 110mm morimoto rgb halo's with Bluetooth control, Raptor style led's in grill, LED's for dome, maps, reverse, license plate, parking lights, switchback DTRL's, ultra-gauge, Kenwood DNX690HD, Hertz HDP4, Hertz HSK165's, Memphis 12" in custom box, Black/Grey Roadwire leather kit with seat heaters, cool white interior led's from oznium.com, 20" AVEC dual row light bar in lower bumper, 19" AVEC single row light bar in grill,
    Double check your grounds on each side. Check your fuse for high beam. If none of that works, I would also unplug the connector for the high beams and hook them straight to battery and make sure the shield is lowering. If it lowers when you touch it straight to battery then you know they are at least functional and the problem is outside the projector. As far as I remember, there is only one way for the h4 to plug in.
  3. Dec 8, 2012 at 5:15 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm having a similar issue, which wires did you swap?
  4. Dec 8, 2012 at 5:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    A year or more ago, there was an issue with the harnesses that were causing problems with some trucks blowing the HB fuse.
    IIRC, the harness was wired specifically for a ground-switched vehicle (like the 1st Gen).
    Reversing the blue and white wires was the solution.
    Pugga, this is not your problem... the affected units would immediately blow the fuse. You ran fine for 2 weeks before the problem started.
    It was posted that the relay module was redesigned so that it will operate properly with either a ground-switched or hot-switched vehicle.
    When I got in on the group buy, I forwarded the thread to Andrew asking if the issue had indeed been resolved and he never responded.
  5. Dec 8, 2012 at 5:28 PM
    Pugga
    Massachusetts
    Ah, good to know. Wasn't even aware of that issue.
  6. Dec 8, 2012 at 5:37 PM
    Burgess65
    By check your fuse for high beam, what do you mean? How would that be tested? About to go try the solenoid wires now...
  7. Dec 8, 2012 at 5:44 PM
    Burgess65
    Ok so the shield does move when it is connected to the battery. So I'm good there..
  8. Dec 8, 2012 at 5:53 PM
    Pugga
    Massachusetts
    Check the high beam fuse in the under hood fuse panel. There are 4 fuses for your headlights, LH high beam, LH low beam, RH high beam and RH low beam.
