No High beams... need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by MyTaco, Dec 15, 2008.
  1. Dec 15, 2008 at 6:48 PM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    On my 94 pick-up when you pull the switch to flash the high beams they work but when you push the switch to engage them on they go out completely. I've installed a new switch and it does the same thing. Is there a relay in line somewhere????
  2. Dec 15, 2008 at 7:21 PM
    MyTaco
    Az
    08 Prerunner
    Thanks!...It does have a relay...just gotta find it...lol
  3. Dec 15, 2008 at 7:49 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    one quick way to check if the relay is good would be to try the high beams and listen for the clicking from the relay. it should be loud enough to easily hear it.
  4. Dec 15, 2008 at 8:00 PM
    MyTaco
    Az
    08 Prerunner
    The only clicking you hear is the switch on the steering column....but you can flash the brights but still hear no clicking anywhere else.....
