no high beams
Discussion in 'Lighting' started by trussell456, Dec 17, 2012.
  1. Dec 21, 2012 at 10:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Nope. One positive power feed to each side. Separate switched high and low beam grounds.
  2. Dec 22, 2012 at 1:47 PM
    trussell456
    trussell456 [OP] Well-Known Member
    Tyler
    Maine
    03 TRD V6 5-Speed
    Bilstein 5100's / Eibach's / AAL / All Pro Front Bumper / Skids / Billet Grill / 33x12.5x15 Duratracs / Dick Cepek DC-2's / TRS Retrofit / 20" Light Bar / 6" HID Fogs / Wet Okoles / WeatherGuard Tool Box
    Oh wow now i feel stupid, tried it like that and the factory plug gets power when the high beams are on. That leaves me to believe the relay control box from TRS is faulty. Contacted Andrew about the issue.
  3. Dec 22, 2012 at 9:00 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I think you are on the right track.
    The only reason I know about the switched ground is I learned the hard way on my previous Toyota truck. I had built a heavy duty harness to run 80/100W H4 headlights. It's a screwy system, and all kinds of odd things can happen if you hook into it like it's a positive switched setup.
  4. Dec 23, 2012 at 7:39 AM
    trussell456
    Tyler
    Maine
    03 TRD V6 5-Speed
    Unfortunately trs is closed until Wednesday for the holidays. Hopefully he can send out a new relay box short after that.
    Thanks for the help guys! Appreciate it. Have a great holiday
  5. Dec 27, 2012 at 7:54 PM
    sebassusmc
    sebassusmc Well-Known Member
    kevin
    va beach
    09 dub cab trd
    fox's on all 4 corners, expo leafs, BHLM D2S retro fit, custom grill, black out badges, lower bumper plasti- dipped........
    ok i have had my d2s retros in a couple months and bout 2 weeks ago the drivers side started acting up but would go back to low beam.it was stuck on high beam but i unplugged the projector and it went back but now its stuck again and i cant get it back to low beam. TRS said to make sure every thing on the slides are not bent and from what i can tell they are now.
    any one had this or know how to fix it? thanks
