No Horn
Discussion in '1st Gen. Tacomas (1995-2004)' started by PcBuilder14, Jan 23, 2012.
  1. Jan 23, 2012 at 9:42 PM
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Recently realized my horn doesn't work, and my inspection sticker goes out at the end of January. Would it be able to legally pass if I just rewired it to a switch? I think the wiring for the horn is probably the hardest thing to follow...
  2. Jan 24, 2012 at 5:20 AM
    PcBuilder14
    Brent
    Nor Cal
  3. Jan 24, 2012 at 5:23 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    do you need a horn to pass inspection?
  4. Jan 24, 2012 at 10:03 AM
    PcBuilder14
    Brent
    Nor Cal
    If I remember correctly you do. the place I go to only checks for turn signals, brake lights, wipers, and possibly horn if I remember correctly.
  5. Jan 24, 2012 at 10:33 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I dont know about your inspection system there, but here as long as the horn works it passes. Doesnt matter if its connected to the steering wheel or to a switch on the dash.
    Does the horn work though? Have you removed it and tried to connect it directly to power? Mine stopped working one day, when I took it out the connector was all dirty and corroded. Cleaned it up and it worked again.
  6. Jan 24, 2012 at 10:53 AM
    bpkrules
    bpkrules Well-Known Member
    Jon
    Houston
    Tacoma4x4 BATMAN
    ARB Front bumper. Custom rear bumper. ARB snorkel. 883s 90004s. 1 inch daystar body mounts lift. Full skids. Leather seats.
    Horn has to work in Texas.
  7. Jan 24, 2012 at 12:55 PM
    PcBuilder14
    Brent
    Nor Cal
    Checked fuse, followed the wiring as best I could and didn't see any problems. I'll test the horn with direct power next. I can't see anything that would be causing problems, I'd rather fix it right, but if the horn itself works and it's something with the wiring then the only choice I have is to wire it to a switch so I can pass my inspection in time.
  8. Jan 24, 2012 at 1:48 PM
    ailll1
    ailll1 Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
    Had a bad ground on mine. Wire wheeled the bracket, bolt and frame where its attached.
    You should try that also if the horn works when connected directly to power.
  9. Jan 25, 2012 at 5:25 AM
    PcBuilder14
    Brent
    Nor Cal
    Where is the ground for it at? I'm having trouble following the wiring.
  10. Jan 25, 2012 at 10:19 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    I think wiring it to a switch will work. As long as you can use the horn it doesnt matter. My guess anyways.
    You have cruise controll?
    Check to see if that still works.
    If it doesn't than I'm willing to bet that it's the clock spring.
    If you don't have cruise control than it still might be it, it'd just be harder to pin down as the problem.
    You have any front end work done recently?
    If it does turn out to be your clock spring, than you should definately get it fixxed ASAP. It connects to your airbag as well.
  11. Jan 25, 2012 at 10:24 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    does your emergency lights button work
