No Idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shiner 1, Sep 20, 2012.
  1. Sep 20, 2012 at 10:58 AM
    Shiner 1
    Shiner 1 [OP] New Member
    Brian
    Texas
    2004 Tacoma
    Again on my 2004 Toyota Tacoma 2rz-fe I have no idle. What
    gives. Runs good other wise but will not idle. Any ideas.
    Brian
  2. Sep 20, 2012 at 11:15 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Idle air control valve on the throttle body.
    1. Needs to be cleaned
    2. Needs to be replaced
  3. Sep 20, 2012 at 11:16 AM
    dually
    dually Low and slow
  4. Sep 20, 2012 at 12:20 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Check the FSM... I don't believe the 2rz has an IAC
    thought that was only on the 5vze
  5. Sep 20, 2012 at 12:39 PM
    dually
    dually Low and slow
    They do... I have one in my garage..
  6. Sep 21, 2012 at 7:30 AM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    my mistake... :eek:
    I should have stated, " I thought..."
    ...maybe it was the 3rz that doesn't :notsure:
    oh well... since you know...
    then I would agree that could be suspect.
  7. Sep 21, 2012 at 7:43 AM
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    easy to clean.
    carb cleaner to make spotless,
    then lube the moving parts (i use wd40 but other are better)
    must move freely, not bind
    clean electric contacts and use dielectric grease on them when reassembling
    to prevent oxidation.
    Had this problem many times on my classic saabs, but at least
    the saabs stayed in "limp" mode meaning they ran but ran shitty enough to get you home.
    will do on my 98 as i suspect 14 years of use and no cleaning is leading
    me to highway issues. (preventive maintenance)
