No interior lights...
Discussion in 'Technical Chat' started by Vhmpyr, Aug 29, 2020.
  1. Aug 29, 2020 at 3:33 AM
    Vhmpyr
    Vhmpyr [OP] Member
    Vlad
    black TRD off road
    non
    I am about to pull out the manual for my 2 week old Tacoma. Non of the interior lights are coming on. What are the chances that all the bulbs are out?, I am guessing the fuse may be bad...unless there's a switch somewhere that I dont know about.
    Any ideas????
  2. Aug 29, 2020 at 5:37 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    there are a few fuses that can play a role, but its most likely the 5A "Panel" fuse in the top corner of the interior fuse box (under the drivers dash)
  3. Aug 29, 2020 at 5:40 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    2 week old as in a new 2 week old truck or new to you truck that is not a 2020?
    Wyoming09 likes this.
  4. Aug 29, 2020 at 5:44 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Dome lamp or the lights on the dash when you turn on your parking/headlights?
    TnShooter and Lester Lugnut like this.
  5. Aug 29, 2020 at 11:19 AM
    Vhmpyr
    Vhmpyr [OP] Member
    Vlad
    black TRD off road
    non
    Its a 2020 brand new truck, which pisses me off cause the dealership is almost an hour away.
    Dome lights and map lights do not come on when I open the door or even when I turn them on manually by pressing the light on the map light or turning on the switch on the dome light.
  6. Aug 30, 2020 at 1:07 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Check Power Source!
    When did the problem start or you just now noticed the problem ??
    Hook any Electrical goodies up??
  7. Aug 30, 2020 at 8:57 AM
    Vhmpyr
    Vhmpyr [OP] Member
    Vlad
    black TRD off road
    non
    Everything works. Just the interior lights, the map light, dome light and the visor lights do not work. I only noticed it the other night when I went to get something out.
    Just put a new fuse for the dome under the steering wheel....still not working
  8. Aug 30, 2020 at 9:03 AM
    Vhmpyr
    Vhmpyr [OP] Member
    Vlad
    black TRD off road
    non
    I haven't hooked anything to the vehicle other than my phone charger to project my phone to the screen.
  9. Aug 30, 2020 at 9:13 AM
    Vhmpyr
    Vhmpyr [OP] Member
    Vlad
    black TRD off road
    non
    I just put a new 7.5 amp fuse for the dome light, the fuse went kapoot....seems like its blowing the fuse.
  10. Aug 30, 2020 at 11:50 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Then you have a short to ground .
    A loose bulb in the socket causing an Arc
    The door switch is loose or has failed or any of the other switches
    Correct Size fuse??
    If you can`t figure it out you have the 2 hour round trip to look forward to.
  11. Aug 30, 2020 at 12:14 PM
    Vhmpyr
    Vhmpyr [OP] Member
    Vlad
    black TRD off road
    non
    I can check everything you just mentioned, but if I cant find anything I will have to do that dreaded 2 hour drive.
    Wyoming09[QUOTED] likes this.
