no lift but......
Discussion in 'Suspension' started by boatbuilder, Oct 4, 2012.
  1. Oct 4, 2012 at 1:50 PM
    boatbuilder
    boatbuilder [OP] Well-Known Member
    Jim
    Tonasket, WA
    12 regular cab 4 cyl 4wd
    A lot!
    I have a 2012 Tacoma 4wd standard cab. I want to stiffen my suspension but really don't want to lift it an more than I have to. I also might want to put a pop top camper on it. I think I can solve that issue with Timbren's or Firestone air bags. So who of you experts out there have a solution? I knoqw what I'm thinking but we'll see. Also, why could you take a let's say OME 885 spring and cut off a length of the spring to get the same results as I am wanting? Stiffer spring but the same ride height.
  2. Oct 4, 2012 at 1:56 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Get some new leaf springs for the rear if you have cash. If you don't get an aal.
    Bump stops will not stiffen your suspension. They just make the ride cushier when you max out the suspension.
    Why would you cut a spring? Get some 5100's and set them correctly. Don't screw up a perfectly good spring by cutting it.
  3. Oct 5, 2012 at 6:36 AM
    boatbuilder
    Jim
    Tonasket, WA
    A lot!
    I would cut the spring as the stiffness of a spring is based on the diameter of the steel used (although the length has something, although less to do with it) according to OME. So, in essence I would get the stiffness of the thicker steel used but would take a spring built to lift the truck, lets say an inch and a a half and lower it back down but still retaining the ability to stiffen the suspension. I understand the use of the airbags or Timbrens which would be used only with the camper on. So, I would like a complete suspension to stiffen the ride (I hate the wishy washy ride it has now). I had a 1994 truck that I put a Downey system under that was perfect.
  4. Oct 7, 2012 at 8:07 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    The mushy ride you feel is from the horseshit leaf springs in the rear. I added a AAL to my 2nd gen and it was a world of a difference... I'm sure a new leafpack would be even better.
