No lift Coil Overs for Bilstein 5100's on a Tacoma 4x4 Dbl Cab Longbed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InspectorClouseau, Oct 25, 2017.
  1. Oct 25, 2017 at 1:59 PM
    InspectorClouseau
    InspectorClouseau [OP] Member
    2021 TACOMA CREW LONGBED TRD 4X4
    Hello -- I am replacing all the shocks on my 2005 Tacoma (4x4 dbl cab, longbed) with 200k on it. I bought a set of Bilstein 5100's from Amazon ($380 for the set). I am having trouble though finding replacement coil over springs. Well, it's easy to find them if I want a lift, but it's proving impossible to find them if you don't want a lift. I assume this is a common question and I've searched this forum and found similar threads, but what always ends up happening is all the suggestions are for springs that offer a lift. Thoughts? I would love a link or a model number of something to go of. Cheers!
  2. Oct 25, 2017 at 2:08 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
  3. Oct 25, 2017 at 3:11 PM
    Pigpen
    Dan
    Northwest Montana
    Old Man Emu springs ride much nicer than stock springs and come in many lengths. There are many members on here running OME springs with no lift. For the double cab long bed V6 4x4, I believe the correct spring for you is the 883. Start your search there.
    Many people think that each spring gives X" of lift period. Not true. It's totally weight dependent, so stock configuration and modifications to the truck come into play. As an example, my access cab V6 4x4 got 2.5" of lift from 885 coils. The weight of my skid plates and winch brought that down to about 2". Many people will tell you those springs give 3" of lift.
  4. Oct 25, 2017 at 3:14 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Aren’t people who did lifts selling their stock springs on eBay, Craigslist, etc?
  5. Oct 25, 2017 at 3:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    pick up stock springs from our for sale section, post as a WTB.
    Specify what year, model and mileage you want.
    Or call Marie @HeadStrong Off-Road and have her ship you out the right pair for your goal.
    HeadStrong Off-Road likes this.
  6. Oct 27, 2017 at 2:22 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so very much @Clearwater Bill for your recommendation we truly appreciate it! :cheers:
