No-Lift Leaf Spring Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aviolette, Mar 15, 2013.
  1. Mar 15, 2013 at 5:54 AM
    aviolette
    aviolette [OP] Member
    Portland, ME
    08 Access Cab SR5
    I have the TSB rear leaf springs, and broke one of the springs on the drivers side. I'm looking for a set of springs without any lift, I just don't want to deal with the hassle of lifting the front. However, at the same time, I'd like some springs that can handle a heavier load. Anyone have any suggestions?
  2. Mar 15, 2013 at 6:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You're likely in custom leaf pack territory. Try a local spring shop or a place like Alcan or Deaver. They can make you a set of springs for whatever speciifications you wish (lift, load, etc).
  3. Mar 15, 2013 at 6:18 AM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    How about these? Handles a heavier load, may sit slightly higher it says though. Call Wheelers and ask if you're interested.
  4. Mar 15, 2013 at 6:24 AM
    acdronin
    acdronin Well-Known Member
    I called Alcan and they said they can make a custom pack to do basically anything I wanted, not cheap, but the good stuff rarely is
  5. Aug 1, 2016 at 6:35 AM
    Vol4life
    Vol4life Member
    2013 Red Tacoma TRD
    I have a 2013 Toacoma that is not covered in the TSB yet but is does have the 3 leaf rear springs. It is soft and sagging. I have also developed a random non reproduceable vibration in the rear end that comes and goes at different speeds. Toyota tells me it is the springs and they need to be replaced. I don't want to add any lift but would like a little stiffer spring. What did you end up going with and have you been pleased?
  6. Aug 1, 2016 at 6:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    The original poster hasn't been here since 10/14, and the thread is over 3 years old. So doubt you'll hear from him.
    For a bit of modest capacity I'd use airbags and call it good.
