No lift wanted just your suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 01willtaco, Jul 7, 2025 at 10:38 AM.
  1. Jul 7, 2025 at 10:38 AM
    01willtaco
    01willtaco [OP] Active Member
    Will
    Phx. Az.
    2018 White Toyota Tacoma TRD offroad accesscab
    I wanted to ask for recommendations for my 2018 Toyota Tacoma TRD offroad. It is an access cab, question: I want to replace the front stock coils and replace them with a heavier duty coil that does not provide lift. I replaced my rear shocks recently with Bilstein 5100s with the stock leaf springs. I would like a spring that will allow for a stock ride height but also have increased load capacity because I want to add a bumper and perhaps later a winch. I plan on going with the Bilstein adjustable 5100s in the front also and understand you can set them at 0 lift. If necessary I can adjust them later to compensate for additional weight and understand that may cause a harsher ride and suggestions are appreciated.
  2. Jul 7, 2025 at 11:01 AM
    bbal
    bbal Well-Known Member
    ‘23 CSM DCSB 6spd
    I too have the same need. My experience with airbags was not good. I’m having them removed. I bought sumo springs and will give them a try (installing them in a couple weeks) and report back in about a month after a towing trip of about 2000 miles. If they doesn’t work I may try to use the roadmaster active suspension which seems to get excellent reviews. Unfortunately, however, it does raise the rear about an inch on a stock Tacoma per the RAS support team. After speaking directly on the phone with somebody from Bilstein I found out that the 4600s are not compatible with even a 1” lift, so I’d have to switch out at least the rear for 5100s. Of course then it’s an even larger rake and then I’d have to change out the front as well and probably use a block. I have not found any replacement springs or any other setup that would not raise the rear. Damn the suspension rabbit hole
  3. Jul 7, 2025 at 12:07 PM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    That's not how it works. At least not with 5100s. The lowest 5100s go is 0 lift with the stock coils. If you use higher rate coils, the weight of the truck can't compress them as much and you get lift. You have to add the weight at the same time as replacing the coils to not get any lift. Or add the weight first and live with the lower ride height until you can replace the coilovers. That's the route I would recommend as it's hard to guess at what coils you will need before hand.
    5100s also aren't necessarily adjustable... You have to remove and disassemble them to change the circlip settings. They are re-configurable, but there really is nothing to adjust. And you need a coil compressor to do this. So not exactly a DIY friendly process.
    Also, 5100s aren't really the best shocks for additional weight. They are factory replacement shock meant to be used with factory springs. If you put a heavier spring, you get a more violent topout which can damage the shocks. I'm pretty sure you even void the warranty when using anything other than OEM coils with 5100s. 6112s are better suited for additional weight and are also "adjustable" like the 5100s.
    scocar, Chew, Snobdds and 1 other person like this.
  4. Jul 7, 2025 at 5:29 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    You should add as much weighty mods first before suspension changes as increasing weight, front or rear, changes your spring needs. I too wanted low as possible with MOD weight.
    Also, the heavier 3rd Gen is going to have different stock springs than a 2nd Gen.
    Chew likes this.
  5. Jul 7, 2025 at 11:13 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    ^^^ THIS
    Add all your mods and then contemplate your suspension and lift needs. Unless you desire to constantly change things like I do.
    Chew likes this.
  6. Jul 7, 2025 at 11:22 PM
    TacoPacific
    TacoPacific Just a Joe in a Taco
    Vancouver BC
    2021 Tacoma TRD OR DCSB
    Smartcap Evo Sport, Gar-FAB tailgate panel, TRD Performance Suspension/Lift
    I'm on my third suspension setup. Like others have said, either change suspension and hope for the best. Or plan, and have a reputable shop assess and recommend some options.
    I have the Icon RXT with AAL, used to overland with RTT, firdge etc, and now I have a small travel trailer instead. If I had skipped a good leafpack, I would be doing it now.
    FWIW, I run Elka 2.0 which gave me a 3" lift ultimately. And it kept the ride level.
  7. Jul 9, 2025 at 9:05 AM
    01willtaco
    Will
    Phx. Az.
    I added the bilstein 5100s to the rear of my 2108 Tacoma TRD o/r and it did not increase the rake on the vehicle.
    As to the coils the way I understand it and please let me know if I am wrong. You are able to get a coil with say 2-600lb increase in compression and it does not raise the vehicle at all.
    The coil is the same height as a ome coil so it does not provide lift. If Im wrong please excuse my ignorance.
  8. Jul 9, 2025 at 9:20 AM
    scocar
    scocar hypotenoper
    There is no "lift shock" for leaf springs. Changing the leafpack adds lift. Blocks and extended shackles not advised. They create new problems.
    Coil springs have several variables, mainly coil height and spring rate (think thinner or thicker coil diameter in the simplest sense). Many different combinations are available. The shock inside the spring should be selected based on the spring rate, because the shock needs to manage and dampen the coil's compression and rebound.
    An experienced pro vendor is your best source of advice.
  9. Jul 9, 2025 at 10:22 AM
    01willtaco
    Will
    Phx. Az.
    thx Scocar and Tacopacific think ill ask for a vendor opinion seems like the best solution.
