No light but headlights need help fast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BJKing, Feb 2, 2011.
  1. Feb 2, 2011 at 11:09 AM
    BJKing
    BJKing [OP] Active Member
    BJ
    Vermont
    09 DC 4X4
    Toytec 3", toyo 285/75r16 Pioneer AVH-p3200dvd Black Badges Fog Lights anytime mod
    I have a 2009 Toyota Tacoma double cab. My taillights are not working, the front marker lights are not working, the 4 way flashers blink 1 time then nothing when I turn them on. I checked the fuses under hood, they are all good. I need help please! I work nights and need them tonight to drive to work.
  2. Feb 2, 2011 at 11:11 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    bump, sorry i cant help :(
  3. Feb 2, 2011 at 11:12 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    U do any wiring mods lately?
  4. Feb 2, 2011 at 11:15 AM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Might be a defect on your taco might want to look up recalls on your year?
  5. Feb 2, 2011 at 11:15 AM
    BJKing
    BJ
    Vermont
    09 DC 4X4
    Nothing new noticed on my way home this morning when I pushed the brakes the dash lights would dim
  6. Feb 2, 2011 at 11:16 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    have you done any offroading lately? make sure the hitch wiring plug below your bumper isnt damaged. If the prongs in the plug are touching it will make your lights do weird things
  7. Feb 2, 2011 at 11:17 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    take it to the dealership your under warrenty
  8. Feb 2, 2011 at 11:18 AM
    BlueTaco07
    Cody
    Looking
    Bad battery?
  9. Feb 2, 2011 at 11:21 AM
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    man use some commas or something, im having a hard time understanding what youre saying here.
  10. Feb 2, 2011 at 11:26 AM
    BJKing
    BJ
    Vermont
    09 DC 4X4
    Is that better
  11. Feb 2, 2011 at 11:27 AM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    You say you checked all the fuses under the hood and they are good. Double check your owners manual because there may be another fuse box you need to check.
    Sometimes fuses (especially the mini plastic ones) may look good but are bad. Are you checking them with a meter??
  12. Feb 2, 2011 at 11:37 AM
    BJKing
    BJ
    Vermont
    09 DC 4X4
    Checked trailer, plug it is ok. The battery is good, and I checked the fuses with a meter.
  13. Feb 2, 2011 at 11:41 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Did you check the fuses behind the coin holder, to the left of the steering wheel in cab?
  14. Feb 2, 2011 at 11:51 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If you didn't check these, then start with the IG1 fuse.
  15. Feb 2, 2011 at 12:13 PM
    BJKing
    BJ
    Vermont
    09 DC 4X4
    I just checked there the fuse is blown. I replaced it and it blew again so I am guessing bad ground or short somewhere.
  16. Feb 2, 2011 at 12:19 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    I didn't think a bad bulb could consistently blow a fuse...sounds to me like a short in the wiring somewhere.
  17. Feb 2, 2011 at 12:40 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Maybe you got a rat that crawled up in there and chewed up some wires :D
  18. Feb 2, 2011 at 12:49 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    If a bulb is working, then it blows - it can blow the fuse. But after the bulb has blown and the fuse is replaced, it shouldn't continue to blow the fuse should it?
  19. Feb 22, 2011 at 3:15 AM
    BJKing
    BJ
    Vermont
    09 DC 4X4
    It was broken tail light wire on trailer harness just where it comes out of the tail light.
