No Limited slip on 4cyl 4x4's?
Discussion in '4 Cylinder' started by roddy1, Nov 2, 2008.
  1. Nov 2, 2008 at 8:36 PM
    roddy1
    roddy1 [OP] Active Member
    Hey guys i have been looking at the 09' Tacoma Access cab, 2.7L 4x4, 5speed.... up here in Canada its the first time for the 05+ taco to be offered with the 4cyl/4x4 option.
    Now in looking at whats standard and optional on these trucks i see no Limited slip or Locker is available as an option from toyota.
    Is this the case with all of them? or just a canada only thing? :rolleyes:
    Im curious if anyone has added one aftermarket? if it affected warranty... and how your truck functions off road without one.
    Thanks
    Roddy
    *Also is a selectable Locker available for the front diff? (like an air locker.. something that wont affect everyday driveability)
  2. Nov 3, 2008 at 4:30 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Nov 3, 2008 at 4:55 AM
    taconinja
    taconinja Well-Known Member
    Pittsburgh
    08 Base 4X4
    Toyota: taking a page out of the VW traction book. Boo.
  4. Nov 3, 2008 at 2:49 PM
    roddy1
    I dont think you can...
    I have the canadian brochure right in front of me and it offeres the Limited slip diff on the V6 models, and the Locker on the TRD models.. again TRD showing only available with the V6
  5. Nov 3, 2008 at 10:36 PM
    Janster
    Jandy
    Lancaster, PA
    I thought I saw it listed on one of the webpages - but apparently not (I stand corrected). Looks like you need to buy one down here! :D or get a V6.....
  6. Nov 7, 2008 at 8:22 AM
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    I read on another post that you can add a Detroit True Trac (LSD) to both front and back. About $450 each (USA). I've emailed a distributor to get parts numbers. I'll repost when I hear anything.
  7. Jan 3, 2009 at 7:52 PM
    Soundwave
    Soundwave Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    Hey Roddy. Im Canada too and I ordered a 4 cyl Access Cab 4x4 (Its about time they were selling them Canada) It should arrive this week, but anyway, about the limited slip, I don't believe it was ever available on the 2005 and newer 2nd gen Tacoma 4cylinder 4x4's, only the V6 and TRD 4x4's. But now new for the 2009 in all models is the traction control and stability control. So now the 4 banger gets that at least. Limited and locking rear diff would be nice! But I dont plan on doing any crazy off roading in a brand new truck anyway. Ill let you know how the 4cyl 4x4 is when I get it!
  8. Jan 10, 2009 at 6:34 PM
    Soundwave
    B.C. Canada
    OEM Roof rack
    ive been driving my awesome 09 4 cylinder 4x4 for the last few days now and its proving to be a great machine! Im pleased with the power so far. But going back to the main topic of this thread: limited slip. All the 09's are equipped with A-trac, and stability control. Im still having trouble wrapping my head around this system. The owners manuel doesnt really explain what it all does very clearly either. I do know in the bit of snow a slush that I have driven in, with all the systems in the default "on" mode, it really cuts the power when the wheels start to spin, in 2WD or 4WD. THis might be good for situations where you don't expect it to get slippery and could save you from spinning out. But when you want to hit the throttle and blast through some snow its really a pain in the ass! It feels like the motor is dieing on you and then you really get stuck! But, it most slippery situations it does get you going when in 2WD.
  9. Feb 12, 2009 at 1:47 AM
    roddy1
    ^^^ interesting. Id like to hear from anyone who is planning to add a limited slip to their 09'
  10. Apr 29, 2009 at 5:54 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Push the VSC button. Truck goes into Auto LSD mode. 2WD only.
  11. Apr 29, 2009 at 10:15 PM
    bullet_magnet
    bullet_magnet Active Member
    you can get TRD off road on 4cyl's? show me that
  12. Apr 29, 2009 at 10:50 PM
    Soundwave
    B.C. Canada
    OEM Roof rack
    Um, no, they don't. Go to Toyota.com or Toyota.ca no such option.
  13. Apr 30, 2009 at 7:31 AM
    glhsracer
    glhsracer Life is good.
    Michigan
    08 4x4
    I too have a regular cab 4x4 and would like a limited slip or locker. Looks like it was never offered from the factory. The Tru Trac is looking pretty good right now.
  14. Apr 30, 2009 at 9:24 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    For what it's worth, Auto LSD means that the rear diff is open. I just installed a Powertrax No-Slip Auto Locker in the rear diff of my '06 which is a simple spider gear replacement that cannot be performed on a true LSD. For that reason I was glad that the 4Cyl 4X4 isn't a true LSD. I really like the Auto Locker, but it might not be the answer if you.
  15. Apr 30, 2009 at 9:27 AM
    drew02a
    San Antonio, TX
    Also, there are ways to disable VSC and Auto LSD so you don't experience that loss of power.
  16. Apr 30, 2009 at 1:09 PM
    glhsracer
    Michigan
    08 4x4
    Any links on what you installed? Did you do it yourself? Thanks.
  17. Apr 30, 2009 at 1:27 PM
    drew02a
    San Antonio, TX
    I installed the Powertax No-Slip automatic locking differential by Richmond Gear. I Bought mine on eBay
    There are several threads here discussing the merits of Auto Lockers search Lock Right or Powertrax.
    My installation took awhile because of some complications. I didn't take any pictures, but these sites were invaluable to me. I'm happy to answer any other questions you might have.
    Installations:
    http://www.atarmor.com/3rdmemwriteup/writeup2.htm
    http://www.yotatech.com/f129/third-member-removal-aussie-install-163698/
    http://www.toy4x4.net/rear_locker/index.htm
    Toyota Diff Info:
    http://home.4x4wire.com/erik/diffs/
    http://www.toysport.com/Technical Information/Toyota Differentials Identifications.htm
  18. Apr 30, 2009 at 6:04 PM
    Isthatahemi
    TRD OFF ROAD
    Mechanically open, but the ABS actuated LSD works better than many mechanical limited slips, in the sense that it doesn't need ANY traction to initiate a limited slip effect, and no dragging effect around corners. Whereas a mechanical LSD has a "breakaway torque", which once exceeded, will not apply any more pressure to the clutch pack, unless the spinning wheel has a least some degree of traction. (One wheel on ice). The ABS actuating on the electronic system will transfer torque, without any other factors.
  19. May 1, 2009 at 6:30 AM
    drew02a
    San Antonio, TX
    The "ABS Actuated" or Auto LSD better than nothing, but it does not have the same power you get from a true LSD or Locker. It's designed for loss of traction on the street. Those kind of systems aren't good for trails or anything really ugly.
  20. May 1, 2009 at 6:42 AM
    glhsracer
    Michigan
    08 4x4
    I do not have personal experience with the Auto LSD but I suspect you are correct in your last post. I have a 67 Mustang with a Detroit Locker and know how well these units work, I can only assume there would be similar benefits with a Power Trax on my Tacoma. Thanks for the links.
