No Longer is he Incompetent Toyota Service Advisor? Would You Allow This ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shumock, Jun 10, 2019.
  1. Jun 10, 2019 at 7:53 AM
    #41
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Agreed, especially if you go between this thread and the 2019 Tacoma Truck Tunnel thread.
  2. Jun 10, 2019 at 7:53 AM
    #42
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Why would warranty from the manufacturer cover road hazard? Not a defect in the tire if you run over something...
    Manufacturer warranty will typically only cover rapid tread wear or defect in the actual manufacture of the part
    Jaque8 and daddy_o like this.
  3. Jun 10, 2019 at 7:56 AM
    #43
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Many people do not understand warranty or think they are entitled to everything for free. I see this everyday, and it is worse with boaters.
  4. Jun 10, 2019 at 8:04 AM
    #44
    ICU1
    ICU1 Well-Known Member
    When I saw the tunnel thing, I thought OP was asking about the boot that goes between the window of the cab and the window of the topper
  5. Jun 10, 2019 at 8:07 AM
    #45
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Someone said it earlier, but why not just cycle the new (non-matching) tire to the spare? You may never use the spare, and if you do, it will only be temporary (my spare doesn't match my other tires, and it's on a steel rim anyhow!).
    Then you can just chalk it up as a learning experience and move on.
    Thunder Fist, ICU1 and kakwvu like this.
  6. Jun 10, 2019 at 8:29 AM
    #46
    Wengel21
    Wengel21 Well-Known Member
    Ben
    SoCal
    2017 DC LB TRD OR
    I say return the tire, put the spare tire on drive to costco or discount tire, have them order the right tire and then call it good. 2 cents dropped into the wishing well
  7. Jun 10, 2019 at 8:33 AM
    #47
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Be PATIENT
  8. Jun 10, 2019 at 8:34 AM
    #48
    Tunngavik
    Alberta, Canada
    Add it to the list in the thread :thumbsup:. It's a crap shoot as to what a 2019 Tacoma Tunnel is until OP responds :popcorn:
    Thunder Fist likes this.
  9. Jun 10, 2019 at 8:40 AM
    #49
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It is because of TW I have to wear mismatched socks
    Deacon Blues and DocD like this.
  10. Jun 10, 2019 at 8:44 AM
    #50
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Wow, just wow.... You have had plenty of advice on here, so stop pissing in your own cheerios.
  11. Jun 10, 2019 at 8:53 AM
    #51
    Kwikvette
    Fresno County
    4 run, 2 don't
    OP has yet to return.
    :popcorn:
  12. Jun 10, 2019 at 8:54 AM
    #52
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    It’s 6am there. Should be back soon :popcorn:
  13. Jun 10, 2019 at 9:29 AM
    #53
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Back when I used to drive beater vehicles I didn't give a crap if I had 4 different tires as long as they were reasonably close in size and had at least 1/16" tread. All I was looking for was to get from point a to b. Now, my Tacoma is my baby and my OCD would not let me live with an odd-ball tire on there. That said, I'd give the dealership a little more time to correct the situation, with the only acceptable resolution being put the proper matching tire on there. If you want to settle for having them put the spare on your good rim and mount that, using the odd tire as a spare I think that would be acceptable with them giving you some sort of discount for the time and trouble. Your choice, but I'd leave any talk about legal actions out and just try to reason with them.
    DocD likes this.
  14. Jun 10, 2019 at 9:51 AM
    #54
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    This is good advice. When I traded my 1st gen (04) for my 3rd in March of 17 the spare on the 1st gen was the one put on at the factory. It still has the mold table on most of it. Probably had run less than 1K miles if at all, I think I rolled it 10-12 feet total to clean and air it up. I was second owner of that Taco and only dropped the spare to check pressure and lubricate the hoist mechanism 2 or 3 times.
    Taco_Craig[QUOTED] likes this.
  15. Jun 10, 2019 at 10:02 AM
    #55
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Going to need that link, for research purposes.
  16. Jun 10, 2019 at 10:04 AM
    #56
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    You cant patch a sidewall of a tire. Even if it's close to the sidewall the tire is toast. I wouldn't put me, my family or others on the road at risk because I patched my sidewall. Sometimes a tire is not repairable and you need to buy a new tire.
    daddy_o likes this.
  17. Jun 10, 2019 at 10:11 AM
    #57
    Tunngavik
    Alberta, Canada
  18. Jun 10, 2019 at 10:17 AM
    #58
    verynearlypure
    Ernest
    The Buckeye State
  19. Jun 10, 2019 at 10:37 AM
    #59
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    I think you guys are being pretty rough on the OP, ya, paying that kind of money for a tire is a bit much!!, so I guess we could all agree he/she is a little naïve when it comes to vehicles, However it would be interesting to know just how many of you are running mismatched tires? (at least he is smart enough as to not to want to do that) jmop
  20. Jun 10, 2019 at 10:41 AM
    #60
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Don’t think the problem is running mismatched tires, it’s most likely that he missed it on the work order that they didn’t have that tire and he signed off on it anyhow.. then said he’d dispute a signed charge or take the dealer to small claims (again, over a signed charge).
    That.. and Servco is the only Toyota spot on Oahu. I’d be careful burning that bridge if he’s not moving anytime soon.
    El Duderino and DocD[QUOTED] like this.
