No Longer Needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MojaveMadman, Jul 7, 2016.
  1. Jul 11, 2016 at 6:42 AM
    #41
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
  2. Jul 11, 2016 at 7:58 AM
    #42
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    Sniping harness. Would like to see photos of the install if possible.
  3. Jul 11, 2016 at 9:06 AM
    #43
    MojaveMadman
    MojaveMadman [OP] Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Ok so here is the harness info for you guys.
    If you have factory fogs: I am waiting for female Delphi weather connector to arrive. It is not a generic one of course, it is a special socket. This will be a pic tail that you can connect to the wires on the LED pod and will allow you to plug it into the factory harness.
    If you do not have factory fogs: You can buy a two lead LED harness from me (Cali Raised brand) for $15 or you can order one from Amazon by MicTuning, OPT7, or that many others out there. I prefer the MicTuning that comes with a nice switch. They are all simple to connect and are complete.
    As far as install goes, I will post some pictures of that and also of the LED output once I get the finals built. I am waiting for hardware to arrive tomorrow and then I will be building out 20 pairs. Once I have them I will post pics of the final product and the install.
    To explain, it is a rather easy process. You first need to remove the factory fog (if applicable). This is a simple process, you can take the whole unit out with a flat head screw driver. There are two clips that get pushed in on each side of the housing, then one clip on the back that requires you to squeeze two tabs. Once it is lose you can disconnect the wire and its out.
    Install will be even easier. The LED bolts to the mount, each one is held on by two bolts and nuts. Once the LED is mounted to the mount, it simply slides into place. There is one 4" long 3/8" diameter bolt that goes into the original mounting hole of the factory fog. You put a washer and nut on the bolt and tighten down until it is snug. Plug in the harness, and off you go! If you don't want to buy the harness, then cut the factory harness off and connect the wires.
  4. Jul 11, 2016 at 9:15 AM
    #44
    conifers4
    conifers4 Tired and Broke
    Brian
    Long Island, NY
    2010 DCLB 4X4
    Excited for this!
    MojaveMadman[OP] likes this.
  5. Jul 11, 2016 at 4:27 PM
    #45
    1madmnky
    1madmnky Well-Known Member
    Tony
    Kansas via Fullerton 714
    2010 Tacoma 4X4 DCLB
    Hella Supertones
    Sweet!! Can't wait for the pics.
  6. Jul 11, 2016 at 4:37 PM
    #46
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Working with @CaliRaisedLed and we think we have a plug harness pinned down. He is working to get some built up for you guys!
    1madmnky and Aussiek2000 like this.
  7. Jul 11, 2016 at 4:49 PM
    #47
    Hungoverspoon
    Hungoverspoon Member
    Devon
    Shawnigan lake BC
    2009 Tacoma Black double cab long box TRD
    Ome lift with spc LR uca's and Dakars on the back. Konig six shooters wrapped with 275/75/r17 all terrain t/a ko2's Apex fab stealth brackets Apex fab fog light pods CBoy808 tailgate decal and trd decals Prinsu rack Diamondback bed cover Switch pros
    I am Definitely interested in these mounts!
  8. Jul 11, 2016 at 5:58 PM
    #48
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    Me too!
  9. Jul 11, 2016 at 7:32 PM
    #49
    Alex_b19
    Alex_b19 New Member
    Alex
    South Carolina
    2015 Black Tacoma
    I'm trying to find brackets to mount my Auxbeam LED Cubes in my fog light ports and I'm having trouble finding those
  10. Jul 11, 2016 at 7:59 PM
    #50
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    Read up, still in development.
    Sub
  11. Jul 11, 2016 at 8:48 PM
    #51
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    ready to weld up 20 sets of 05-11 mounts tomorrow, did all my prep tonight. Also have a 2012-15 model coming by tomorrow so I can design some mounts for you guys! Moving quickly!!!
  12. Jul 11, 2016 at 9:06 PM
    #52
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
  13. Jul 11, 2016 at 9:33 PM
    #53
    Tacoma005
    Tacoma005 Well-Known Member
    Bellingham, WA
    2005 DCSB TRD Off-Road 4X4
    KMC Crank Rims, 30" Baja Designs light bar, HomerTaco front grill
    Will pod lights such as the Rigid Dually work with this bracket?
  14. Jul 12, 2016 at 5:02 AM
    #54
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    I believe they will as long as the housing is the same. I do not have a Rigid to test it with, but from pics, they look similar.
  15. Jul 12, 2016 at 1:44 PM
    #55
    PaulK
    Paul
    Would be interested in the answer. I'm going to get a set of the brackets and pigtails for my 2013 regardless, but would prefer to use Rigid if they will fit.
  16. Jul 12, 2016 at 3:24 PM
    #56
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    I'm sold. I called the number on his page and Chris answered and was kind enough to answer all my questions. I bought the Flush mount + 4D LED combo a few weeks back and love it!! So gimme gimme!
  17. Jul 12, 2016 at 6:57 PM
    #57
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    If you want to buy just the mounts, we can give it a shot. If there is a problem with them, I will honor to combo price on a set of Cali Raised pods and send those to you.
    Was my pleasure!
  18. Jul 12, 2016 at 7:12 PM
    #58
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Who is ready for 2012 - 2015 Pod Mounts!!!!
    @Nickel came by today and we did some testing. It became clear very quickly that the factory housing needed to go for the cleanest fit and look. So we set out to make something nice. I want to call these 95% bolt on, haha. They require you to drill one 3/8" hole in your bumper for mounting. However, the hole is covered by the factory panel which can be re-installed and you would never know the hole was there. The rest just slides right in with some tabs as the factory mount does, and then you tighten the nut on the new mounting bolt and they are in there!
    These were fun to design. The bumper contour is not flat, so they take a little bit more work and time to fit as the plate has a bend in it. The result is great and they fit nice and tight. The LED pod is not completely flat with the front bumper, but instead aim the LED slightly outward. I think this is a positive and will work great. This moves the light beam outward into the corners so you can see around your truck better. I am still doing some design cleanup/updates to the product to make it perfect. @Nickel will be coming by this weekend for final fitment for you guys! These will make for one killer combo with the lower grill LED mounts I currently offer!!!
    Time for what you are waiting for!!!
    E980F03D-C23A-416A-A54C-E0335BB5E3FB_zps_e16130e8a6d05f7da8f0a9dd39d51172a7a1f019.jpg
    A6120870-D19B-409D-9C12-265A001B6926_zps_db3b521fbf21016fddd2821134f1b66a41cb13af.jpg
    6D9AC1EA-0A83-4B9C-82AC-785DDD97E64C_zps_66c18270eda94f6bd69a24fd86155bdee4f778b2.jpg
    A7D98935-70B2-433D-9AF4-7063F15856D7_zps_0207fd37a244385183b85766de907335d2572399.jpg
    B303DF44-FA26-4690-B011-51B83740CF12_zps_17e5eb5a4cb3e2bd65806ac18e73ce21ca3d81cf.jpg
    2658BE8B-D43C-459E-975E-F2DA56CE52E8_zps_d944a940d0ab5cd19aa1e02633ef80347aec595c.jpg
    And these are the hole you need to drill for mounting.
    0E32B933-7B4D-49B8-870A-4D824172B6F9_zps_6258d89334b6263f932f628fadde2bc8d869e457.jpg
    5FC11057-964E-4D41-A06A-1FE9DFC679D4_zps_dd4ebd80b05e987ef47dc9e7f334af13e9fc0327.jpg
  19. Jul 12, 2016 at 7:19 PM
    #59
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Pricing for these. Sorry I had to add a little bit due to added time and wear and tear on my press brake. It's only $10 more to the total price and worth it for a perfect fit. I didn't want to make some cheap junk. Also, these have a different harness than the 2005 - 2011, thanks Toyota, but @CaliRaisedLed and I will get some made for these plugs as well. The harnesses will tentatively be $8 more if you want one for the pair of pigtails.
    $70 - Mount only, with free shipping
    $119.99 - Mount and pair of 16W Cali Raised Pods, with free shipping
    $129.99 - Mount and pair of 18W Cali Raised Pods, with free shipping
    $134.99 - Mount and pair of 18W Amber Cali Raised Pods, with shipping
    Plus tentative $8 for harness to use factory wiring if desired.
    Lord Helmet, Nickel and Alex_b19 like this.
  20. Jul 12, 2016 at 7:41 PM
    #60
    mrlee
    Reserve me a $129.99 - Mount and pair of 18W Cali Raised Pods, with free shipping
    Edit, will want the piggy for factory fit as well. I hate splicing.
    Will pay on Fri 4sure.
    Mark
