No longer stuck in Riverside. Ratchet strap saves the day despite better judgement.
Discussion in 'Off-Roading & Trails' started by Ambiguouse, Apr 14, 2019.
  1. Apr 14, 2019 at 6:46 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    yeah that's why you're only option to get yourself unstuck is going in reverse, only way you're going forward in 2wd is if someone yanks you up.
    Air those tires down real low (12 psi) and dig, should be able to back out of it.
    Beretta4x4 and tcjacado like this.
  2. Apr 14, 2019 at 6:47 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Bumped to the top!
  3. Apr 14, 2019 at 6:48 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Sub’d - I never knew how much I would enjoy stories of rescued trucks until I joined TW. Good luck OP.
  4. Apr 14, 2019 at 6:48 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Good thing you have that light bar.
    :bananadead:
    FWIW it doesn’t look that bad but it also sounds like you don’t have a lot of experience with recoveries. This will be a learning experience for you. A lot of good suggestions already, you should be able to get out with a little ingenuity.
  5. Apr 14, 2019 at 6:49 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Which part of riverside are you in?
  6. Apr 14, 2019 at 6:50 PM
    Ambiguouse
    Ambiguouse [OP] do you even taco
    Steven
    Riverside, CA
    2015 Tacoma PreRunner Double cab
    -coil spring double wishbone front suspension - rear leaf spring suspension with staggered gas shock absorbers - 16" styld steel wheels BFG tires - engine skid plate - off road tuned suspension with bilstein shocks - 20% front windows tint - limo tint back door widows
    All 4 ?
  7. Apr 14, 2019 at 6:51 PM
    Ambiguouse
    Steven
    Riverside, CA
    Yea man first time getting stuck this bad i hate it I’m trying my best with everyones suggestions
    Spare Parts likes this.
  8. Apr 14, 2019 at 6:51 PM
    eon_blue
    Azusa, CA
    Just the rear 2, you can do all four for good measure but the rears are your drive wheels and those are gonna be what get you unstuck.
  9. Apr 14, 2019 at 6:51 PM
    robssol
    Rob
    S. Wisconsin
    If it gets dark turn on the light bar. Just sayin
    Good luck
  10. Apr 14, 2019 at 6:53 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    This. Free the back two tires and you can get out in reverse.
  11. Apr 14, 2019 at 6:55 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    If you aren't moving and tires start spinning, STOP and dig more. If any of the frame is dug in under the truck, dig that out as well.
    And like mentioned before, if dirt is hard enough, Jack it up and put rocks or sticks under the tire.
    DON'T PUT ANY BODY PARTS UNDER THE TRUCK TO JACK IT UP OR WHILE IT IS IN THE AIR.
  12. Apr 14, 2019 at 6:56 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    This guy is right, floor mats or anything like that can give you just enough traction
    Beretta4x4 likes this.
  13. Apr 14, 2019 at 6:58 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Also once the rear end is out, fill in the holes before getting the front axle stuck in the same spot.
    Spare Parts and Beretta4x4 like this.
  14. Apr 14, 2019 at 6:59 PM
    Ambiguouse
    Steven
    Riverside, CA
    Border line parris on caljalco dr
  15. Apr 14, 2019 at 7:05 PM
    #35
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Dig and air down as everyone else said. I will add that once you get on the road at 12psi, don't drive over 25-35mph until you air up again. good luck man. If I was still back there I'd get you out.
  16. Apr 14, 2019 at 7:07 PM
    #36
    tcjacado
    tcjacado Well-Known Member
  17. Apr 14, 2019 at 7:08 PM
    #37
    tcjacado
  18. Apr 14, 2019 at 7:08 PM
    #38
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    Turn that light bar on and dig.
    Spoonman likes this.
  19. Apr 14, 2019 at 7:09 PM
    #39
    IEsurfer
    Socal
    I can go but just to give you a ride (no recovery gear or shovel) PM me if you need one
    Edit I have a tire gauge
  20. Apr 14, 2019 at 7:21 PM
    #40
    Beretta4x4
    Josh
    Temple, TX
    Bump
    IEsurfer likes this.
