No love for Bull Bars?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by muslmutt, Oct 17, 2015.
  1. Oct 17, 2015 at 6:48 AM
    muslmutt
    muslmutt [OP] Well-Known Member
    SE OK
    2004 SR5 Tacoma Access Cab (Sold), 2015 Tacoma TRD Off Road DCSB
    Seems like most of the trucks I see pictured here do not have Bull Bars. What's up with that? How about some Bull Barred Tacoma pics? I've been considering and am interested in my options.
  2. Oct 17, 2015 at 7:09 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Thread cleaned up
    OP, most people don't like them because they can be what's known as damage multipliers
    Typically made from cheap steel and even in minor collisions have a tendency to fold back and damage parts of your truck that would not have normally been damaged
  3. Oct 17, 2015 at 7:11 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    J. Beam - you da man!! Thanks for your intervention, this forum needs more of that! jmb
    bowhunterRN and JimBeam like this.
  4. Oct 17, 2015 at 7:11 AM
    muslmutt
    SE OK
    Ahhhhhh....... Makes sense. Thanks. If I had not asked I may have wasted money on one.
    Thanks for the clean up, btw.
  5. Oct 17, 2015 at 7:13 AM
    JimBeam
    JB
    2015 Tundra
    There are other options out there that aren't made from cheap steel if you're looking for light mounting solutions but if you're looking for protection, it's hard to beat getting a proper full plate steel bumper
  6. Oct 17, 2015 at 7:14 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    What JB said. Most of the run of the mill Weston and Aries style bars are just that, for style. A functional bull bar like ARB, Road armor, or any number of plate steel fabricated numbers will serve you much better. In the vendors section of TW you can find a multitude of fabricators that build them for the Tacomas.
  7. Oct 17, 2015 at 7:18 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    good info. Did not know this.
  8. Oct 17, 2015 at 7:19 AM
    muslmutt
    SE OK
    I was wanting protection and light mounting options, but not sure that I want the full bumper. I drive 100 miles to and from work every day. Mostly old 2 lane highways through national forest. I leave for work in the dark and get home after dark this time of year. I see a lot of deer every day. Chances are I will hit another one before long.
  9. Oct 17, 2015 at 7:34 AM
    Pigpen
    Dan
    Northwest Montana
    You want a bumper, then. Get one before you have to replace the grill, lights, hood, bumper cover...it'll be more than just the bumper cover that gets smashed. A plate bumper is a good investment in your situation. I have a Buck Stop on my Dodge that has killed a few deer. The Tacoma bumper keeps getting pushed back (pun, I know...) while I do other mods.
  10. Oct 17, 2015 at 7:39 AM
    Dogdad
    Dogdad Well-Known Member
    Metairie,Louisiana
    2015 Pyrite Mica Double Cab
    Do you think it's a good idea to remove the factory tube steps? It's not like my taco is so high I need them on...
  11. Oct 17, 2015 at 7:55 AM
    Pigpen
    Dan
    Northwest Montana
    To a point is correct, Rock. But on a relatively small animal like a deer, you'd have to be on the skinny pedal pretty hard to cross that line. Bending the frame would be the concern, but at that point a stock setup would be destroyed. Now with a full size truck... let's just say I have seen some guys intentionally hit deer in excess of 70 mph in one tons with bumpers. It's pretty dramatic, and maybe a bit appalling - in a kind of humorous way.
  12. Oct 17, 2015 at 8:01 AM
    SethB
    SethB Well-Known Member
    TDY
    **SOLD** 2009 DCLB 4X4 Auto
    OME Suspension, SPC UCAs, ARB Bumper, Smittybilt Winch, Ext Brakelines, SOS Sliders, 4x Innovation Rear bumper
    Factory tube steps are the same, attached to the sheet metal of the cab. You take a good hit to those and they'll bend up into your rockers along with other sheet metal carnage. That's why sliders are attached/welded to the frame.
  13. Oct 17, 2015 at 8:03 AM
    muslmutt
    SE OK
    I am not expecting no damage if I hit one. I am looking for damage reduction. It's all about how you hit them anyway. Last one I hit I got him right in the side of the head with the front left corner of my 2004 access cab Tacoma. Hardly a scratch on my truck, or the deer. But the he deer was dead right there without a twitch.
  14. Oct 17, 2015 at 8:07 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Avid light bar works much better than a bulbar. It saved my bumper many times from people who can't park.
  15. Oct 17, 2015 at 8:07 AM
    Pigpen
    Dan
    Northwest Montana
    You got lucky. They often spin down the side of the truck putting dents in all the panels on their way back. Many times breaking glass along the way. A buddy of mine got head butted by one doe he hit in the family's new mini van (he was a new dad at the time). Hitting deer is never a good deal for those involved - you or the deer. Put the odds in your favor.
  16. Oct 17, 2015 at 8:09 AM
    muslmutt
    SE OK
    Agreed!
  17. Oct 17, 2015 at 8:13 AM
    JimBeam
    JB
    2015 Tundra
    ARB is where it's at
    Designed with crush cans in the mounting system, still airbag compliant, and lit's of video/pic evidence they can handle deer without too much damage
  18. Oct 17, 2015 at 8:14 AM
    Pigpen
    Dan
    Northwest Montana
    I've actually had more deer run into the side of my cars and trucks over the years than I've hit with the front. As you already know correct speed for the conditions, whether that be weather/ road, light, or deer activity, and paying attention is most important.
    MGtaco2.7 and JimBeam like this.
  19. Oct 17, 2015 at 8:30 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I had one on my 2010. Slid on ice into the rear of a car. Bull Bar crushed right into the bumper, grill, up into the hood. Broke tabs on the headlights and damaged the radiator. This all at about 7-10 MH.
  20. Oct 17, 2015 at 8:34 AM
    ShaneG
    ShaneG Well-Known Member
    Shane
    Jacksonville, FL
    11 Prerunner SR5
    I look at the factory tube steps not as protection of the rockers, but protection against door dings. Not an off-road guy, just use my Tacoma for every day commuting. To date, I still remain door ding free.
    JimBeam likes this.
