no low beam but drls work
Discussion in '1st Gen. Tacomas (1995-2004)' started by abilities, Nov 12, 2020.
  1. Nov 17, 2020 at 1:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes if the No4 Relay is good, and there is nothing on the G-Y wire, I too would suspect a diod or ECU.
  2. Nov 17, 2020 at 1:20 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Did you test (or look) if 2003 ECU indeed has just a diode between 13(1L) and 14(1L). I know for the fact that Toyota is very reluctant to any changes in their vehicles within the same model. Their Change management is so strict almost like in airplane manufacturers. So it is most likely that they did not introduce any new functional logic in that area, just shoved in that stand alone diode.
  3. Nov 17, 2020 at 1:27 PM
    TnShooter
    Deogee
    STOCK
    I have no way to test it. I own a 2007.
    And the diagrams I have don’t show anything inside the ECU.
    The 2003 diagram still show a diod separate from the ECU.
    PM inbound
  4. Nov 17, 2020 at 1:42 PM
    RysiuM
    Rysiu
    Thanks. 2000 (and earlier) don't have ECU but have two diodes separating Flash from Headlight. The diagram looks different but the functionality is very identical.
    TnShooter[QUOTED] likes this.
  5. Nov 17, 2020 at 2:36 PM
    TnShooter
    Deogee
    STOCK
    Oh, ok.
    I only have access to 01’ and 03’ diagrams.
  6. Mar 7, 2021 at 5:24 PM
    abilities
    abilities [OP] Member
    2003 tacoma v6
    @turbodb
    @RysiuM
    @jonesbt
    This headlight issue is solved, according to the mechanic its a bad B-ECU. the work around was shorting the switch past the body ecu, i'll post some pictures of what was crimped together if jonesbt is still having this issue.
    thank you everyone for the advice you guys were spot on in your troubleshooting but im just inexperienced in electrical.
    turbodb and TnShooter like this.
  7. Mar 7, 2021 at 5:53 PM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    Photos would be great. Thanks for following up! I actually actuated a new body ECU a couple of days ago but haven’t attempted to install it yet.
  8. Mar 12, 2023 at 5:25 PM
    04Tacoma20
    04Tacoma20 Member
    2004 TRD Off-road Prerunner, 2020 TRD Off-road
    I’m having the same problem on my 04 Tacoma. No low or high beams when switch is turned on. DRL’s are functioning properly, and headlights work in the flash position. Fuses and relays checked good. I have 12 volts at body ecu connector green/yellow wire but 0 volts at the red/green wire and 0 volts at pin 13 of the switch. I’m thinking it may be a problem within the body ecu. Is there any way to test it to be sure? Any help would be appreciated.
  9. May 28, 2023 at 2:09 PM
    04Tacoma20
    04Tacoma20 Member
    Update: Problem resolved. I ended up replacing the Body ECU (fuse/junction-block assembly).
