No magnet on transmission drain and fill plug
Discussion in '1st Gen. Tacomas (1995-2004)' started by grovestreet, Jul 14, 2013.
  1. Jul 14, 2013 at 3:18 PM
    grovestreet
    grovestreet [OP] Well-Known Member
    Hello,
    I just changed the manual transmission fluid on my 04 base, reg. cab with W59 transmission.
    I didn't find a magnet on either the fill or drain plug. Is it normal? Also, can someone comment on the color of the oil remains in the plug? I think the transmission fluid has never been changed in the past 110k miles.
    Also, I accidentally torqued the drain plug to 30 ft*lb (was using a digital torque adapter). Would it be a major problem?
    Thanks!
    BTW: I bought 3 quarts of redline MT90 and it's pretty awesome. It instantly smoothed out the action between 1st and 2nd gear.
  2. Jul 14, 2013 at 3:32 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
  3. Jul 14, 2013 at 5:43 PM
    dstock
    dstock Well-Known Member
    David
    Camp Lejeune
    2011 Tacoma double cab v6 4x4
    URD short throw shifter, halo projection headlights, 8000k hids in headlights and foglights. Made my own color matched satoshi with homertaco mesh.
    i did not have a magnet on my 95 taco with the w59 tranny.
  4. Jul 14, 2013 at 5:50 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    Nowdays, they put a round magnet stuck to the pan close to the drain plug. You would have to actually remove the pan in order to see it.
    Never mind, just read you meant "manual" my bad!
  5. Jul 14, 2013 at 5:52 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    By the looks of the oil on the plug it looks line water may have been introduced to it.
  6. Jul 14, 2013 at 5:56 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    I just changed my trans oil a couple weeks ago and scraped some gunk out of the drain plug with a small screwdriver. Didn't seem magnetic at all to me. There was some brass flecks and some shit that looked like an eraser on the end of a pencil, I'm guessing it was some bits of gasket material.:notsure:
    I'm sure you'll be fine with 30 ft-lbs also. The FSM says 27 ft-lbs, so you barely over torqued it anyway.
  7. Jul 14, 2013 at 6:32 PM
    grovestreet
    Thanks for all the replies. I read several threads regarding changing the fluids and probably just mixed up the plugs on tranny and diff.
  8. Sep 17, 2017 at 4:27 PM
    1997tacomav6
    Denver
    I did my oil change on the diff and 5 speed trans and transfer case and the diff has a magnet but I don't understand why the transmission and transfer case don't, seems strange to me, anyone know if the diff magnet will work for the transmission and transfer case, they are all a 24mm head
