No mic, no bluetooth, no radio controls on steering wheel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by triathloner, Dec 16, 2020.
  1. Dec 16, 2020 at 1:29 PM
    triathloner
    triathloner [OP] Member
    Alan
    2017 Tacoma Sport double cab
    2" lift
    I just bought a 2017 TRD sport last week and absolutely love the truck. It was a repairable hit in the rear and fixed. They changed out the tailgate but didn't hook up the camera. I have a new harness on order for it. Could this affect my problems with the radio? I am getting the no Mic hooked up, and can't connect through bluetooth. I also don't have any radio controls on the steering wheel, but the controls on the right side of the steering wheel work as they should. It has the fancy stock entune touch screen stereo in it. I did disconnect the battery for about an hour and it didn't change anything. I also went in and removed all prior data on it and did the soft restart on it and nothing has changed. Any ideas for me to try?
    Thanks
  2. Dec 16, 2020 at 1:29 PM
    triathloner
    Alan
    2" lift
    forgot to mention that obviously the rear camera isn't working.
  3. Dec 16, 2020 at 1:38 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Check fuses, sounds like a module is down.
    SJBrown likes this.
  4. Dec 16, 2020 at 1:57 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Was the truck totaled out? Meaning, did it undergo major repairs, like sperating frame and body, or reinstalling major wiring harnesses?
    If so, there's no telling really, you'll just have to go through it all, inspecting every connection and centimeter of wiring.
    Sorry, I'm not much help, good luck.
  5. Dec 16, 2020 at 2:01 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The spiral cable that controls the left side steering buttons goes directly to the radio via a white 28 pin connector. The microphone (amplifier) also uses the same 28 pin connector. And looks like the input to tell the radio you're in reverse also uses the same 28 pin connector. Might want to check that it's plugged in.
    Not being a dick. Was just updating my post as I reviewed the diagram.
    mattleg and HisDad like this.
  6. Dec 17, 2020 at 6:51 AM
    triathloner
    Alan
    2" lift
    Thanks for the schematics, this will help for sure. I'll pop out the head unit hopefully tonight and check that everything is plugged in all the way and then run down stream from there and check all the harness.
    ktbell444[QUOTED] likes this.
  7. Dec 18, 2020 at 7:52 AM
    triathloner
    Alan
    2" lift
    Pulled it out last night and the previous owner had hacked apart the existing harness and then repaired it, probably had an aftermarket head unit in and changed it back to the stock one. Frustrating to say the least. I will be spending some time with the meter tonight, and probably with google looking for a new harness.
    Kev250R likes this.
