No more cleats due to tanneau...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Feb 10, 2009.
  1. Feb 10, 2009 at 7:12 AM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Anyone have any recomendations on extra tie downs or D rings? I move a lot of furniture and have a motorcycle. I was reading on the extra D-rings on cheap free mods but am a little bit skeptical.
    HELP!!! I still want to use my truck... as a truck!:confused:
  2. Feb 10, 2009 at 7:21 AM
    Snyperx
    Snyperx Seniore Marcos
    I saw a few other people asking this. I have the Access Limited Edition soft tonneau and I have full access to the rail system and cleats. Access uses a set of spacers to allow full use of the rail system.
  3. Feb 10, 2009 at 7:34 AM
    Brunes
    Brunes abides.
    Rotorhead
    +1. I was stoked when I put I all back together and they work great!!
    The D Ring mod is do-able- Use a large enough plate under the bed you'll be fine.
  4. Feb 10, 2009 at 7:36 AM
    1tacoplease
    Temecula
    I already have the Bakflip G2. I was really happy with the looks and funcoinality (is that a word?) well, with the way it functions ( how easily it folds up ) but was disappionted when I tried to strap something down and realized I only have the 2 rear D rings to tie down to.
  5. Feb 10, 2009 at 8:40 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    doesnt toyota makes 2 different sizes in the clets?i think i heard that. mine fit under my access cover with no problem. i assume you have the bigger ones.(i bet you dont hear that too much...lol)
  6. Feb 10, 2009 at 9:46 AM
    1tacoplease
    Temecula
    I can't use cleats anymore because of my tonneau, unless there is some sort of bracket that you all have heard of? What are the other ways to add D-rings?
  7. Feb 10, 2009 at 12:03 PM
    paintdiddy
    shithead
    silver bullet
    did you have to take off the track system???? i didnt have to on mine
  8. Feb 10, 2009 at 3:59 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    D rings under my bed bolts = 6 tie down points.
  9. Feb 10, 2009 at 4:31 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    I have additonal stock D-rings under my front bed bolts. Solid as a rock! You will definitely need a breaker bar to loosen them up. Use some locktite when you put it back together. Most useful mod I have done to my truck...
  10. Feb 10, 2009 at 4:38 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
  11. Feb 10, 2009 at 7:44 PM
    1tacoplease
    Temecula
    I used the track system to mount the tonneau, so it elimated the whole rail! It gives it a flush look but takes away from the tie downs.
  12. Feb 10, 2009 at 7:48 PM
    1tacoplease
    Temecula
    I did order the rope rings from the online cheap free mods. I just don't like the fact that I have to drill a bigger hole, cut the washers, and drill the threads to take out the washers. I ordered the D-rings to do it, but just looking for alternative ways to do this.
  13. Feb 10, 2009 at 7:49 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    What kind/brand of tonneau did you get?
    Extra d rings mounted under the bed bolts will give you all the tie down points you should need.
  14. Feb 10, 2009 at 9:38 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    You can do it with a file in 30 seconds even. It isn't hard at all to grind those threads under the bolt head off.
    The D ring hole is easy to drill if you have a vise. I don't so I actually used a tap and die kit to do it. Had each hole large enough inside of 5 minutes. A little work to save money plus it keeps me off the streets and slinging crack.
  15. Feb 10, 2009 at 9:42 PM
    1tacoplease
    Temecula
    Okay, I'll do it. I have a dremel, but don't have a tork-55 wrench and don't know how to drill a bigger hole. What did you do? What size do i have to drill the D-ring hole to?
  16. Feb 10, 2009 at 9:47 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Honestly, I just drilled and kept test fitting until the bolt fit. You need a Torx 55, though. And, if you don't have an impact gun which you really need for this, be careful with that breaker bar because those bolts are easy to strip. Oh, and DO NOT CROSSTHREAD THE BOLTS because the bolts are $12 each from the dealer. Go ahead and guess how I know this...
  17. Feb 10, 2009 at 10:01 PM
    1tacoplease
    Temecula
    Thanks for the info but what is cross threading the bolts?
  18. Feb 10, 2009 at 10:21 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    You ever replace a spark plug and when you went to put the new one in its place it threaded ok at first but then you noticed it was getting harder to keep threading in and when you pulled the socket wrench off the new plug it looked like it was threaded in at an angle?.....:frusty:
