No more door courtesy light
Discussion in '1st Gen. Tacomas (1995-2004)' started by imprezivevo, Nov 12, 2009.
  1. Nov 12, 2009 at 9:56 PM
    imprezivevo
    imprezivevo [OP] Member
    02 Tacoma
    So no fuses are broken, no burnt out bulbs...but, no door courtesy light? smelt a burnt smell after what i presume a short circuit, when a black wire coming from the a-pillar (the door courtesy light switch) might have come into contact with a positive?...anyway, the only thing that doesn't work is the door courtesy light switch, the regular dome light works but the "door" option doesn't work anymore when the door is open :confused: can anyone help?! thanks!!
  2. Nov 13, 2009 at 6:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Test the continuity of the switch. If it is ok, I would say the wire is bad.
  3. Nov 13, 2009 at 9:08 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Does the door courtesy light function fail to work for both the driver and passenger side doors?
    If not, the problem is probably in the driver side courtesy switch or the green / white wire from it to the Body ECU.
    If so, I'm guessing the black wire you refer to is the lead from the door position terminal on the dome light back to pin #12 on the Body ECU.
    If it was a bad enough short circuit, I'm wondering if there's a chance you burnt something in the Body ECU.
  4. Nov 13, 2009 at 8:24 PM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    i have this same issue but i know i didnt short circuit anything.
    EDIT
    my issue was fixed. on of the buttons on the doors was loose.
  5. Nov 13, 2009 at 11:38 PM
    MarkOlson
    MarkOlson Gray beard
    Mark
    San Jose, CA
    03 Tacoma Regular Cab
    Check out the schematics here:
    If the dome light is working but the personal lights are not, then it appears that you have burned out the black wire that runs between splice "B" and the personal lights. Trace back that burned black wire and you should find where it melted.
  6. Nov 14, 2009 at 12:27 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    i continued to mess around with mine, i ended up accidently touching the posi and ground wires together for the courtesy lights and now the courtesy lights dont work. i found out the posi is fine, but ground is shot. i didnt find a burnt spot in the ground wire. i checked all the way from the dome switch to the fuse box under the steering wheel(not really sure the exact name?).
    i gave up. i'm assuming im going to have to but a new fuse box.
  7. Nov 14, 2009 at 12:36 PM
    MarkOlson
    Mark
    San Jose, CA
    It looks to me like the fuse box is part of the body ECU. It might be expensive to replace. You could try splicing in a new ground wire just to get it to work.
  8. Nov 14, 2009 at 12:46 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    well, its actually negatively switched. it changes ground to turn the lights on and off. so that wouldnt work. i'lll do more research later when i have more time. i might just make my own module for it if the block is expensive.
  9. Nov 14, 2009 at 1:01 PM
    MarkOlson
    Mark
    San Jose, CA
    So you are saying the B-W wire from the dome light to the Body ECU is good. It does sound like you burned out the interior lighting part of your Body ECU.
  10. Nov 16, 2009 at 5:16 PM
    imprezivevo
    02 Tacoma
    So for mine the courtesy light doesn't work for any doors but the light works when I turn it to the on position so I don't know what to do with that I had trouble tracing the wire but it seems like something did get burned cuz I smelt something burning when those wires did touch they may have touched ( the negative and positive) so I don't know if I did burn out that part of the body ecu...if that did happen what can I do to fix it?
  11. Nov 16, 2009 at 5:18 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    i could be wrong, but i think the only fix is to either trace the wire and find a burnt spot, or purchase a new bcm?
  12. Nov 16, 2009 at 5:48 PM
    MarkOlson
    Mark
    San Jose, CA
    I would use an ohm meter to ensure that all of the wires in question have continuity. If they do and the fuses are all good, then you need to suspect the body ECU.
  13. Jan 12, 2010 at 4:56 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I found a relative! :cheers: sorry off topic
  14. Jan 12, 2010 at 6:20 PM
    MarkOlson
    Mark
    San Jose, CA
    My long lost cousin! And he owns a Tacoma!
    Watch out for that Aqvavit!:drunk:
