No Oil Change at 5,000 Miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by civictotaco, Mar 6, 2011.
  1. Apr 7, 2011 at 8:25 PM
    #41
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Great! all dealers are not created equal.
  2. Apr 8, 2011 at 4:35 PM
    #42
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
  3. Apr 8, 2011 at 5:14 PM
    #43
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  4. Apr 15, 2011 at 8:17 AM
    #44
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Full synthetic oil change required every 5k miles for the 2011 4-cyl Tacoma? That's total overkill and I just don't get it -- might as well pour your money down the drain. At 5k my dino oil still has some good clarity.
  5. Apr 15, 2011 at 8:44 AM
    #45
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If the manual states dino, I use dino. The synthetics seems to be the hot ticket, but dino does not break down normally before the 5000 miles mark, so protection is there. With the diffs and trannys, being longer intervals I feel synthetics may be better, but not sure. I set the clock at 3500 miles, then get to it when I can with my vehicles. Most of the time its between 4000-4500 miles. Please tell me why I should spend the extra $$$? Also, all theses stories of Toyotas going 3-400K was done with dino...:rolleyes:
  6. Apr 15, 2011 at 9:51 AM
    #46
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    and pixie dust??
  7. Apr 15, 2011 at 9:54 AM
    #47
    DGXR
    Friend
    Sacramento, CA
    It is not so unusual for a Toyota 4-cylinder engine to go over 300k miles with normal maintenance using petroleum-based motor oil.
  8. Apr 15, 2011 at 10:05 AM
    #48
    buddywh1
    Philly PA
    07 DC SR5 4x4
    it's not so unusual for a lot of mfr's engines to go that far with good maintenance. it's not the engine, it's everything else that causes the problems that makes it unattractive to keep.
    Problems like rusted out frames, and intermittent electrical accessories, worn suspension, etc, etc. etc. It's a project keeping any vehicle that long.
  9. Apr 15, 2011 at 10:07 AM
    #49
    Cerviperus
    Cerviperus Well-Known Member
    Justin
    Mt. Zion, IL
    '11 PreRunner V6 TRD Off Road
    Grille4You 3" Stainless Nerf Bars, EGR In-Channel Window Deflectors, BAKFlip HD Tonneau Cover, Oznium 5" Blue LED Dome Light, WeatherTech Floor Liners, EGR Bug Shield
    The maintenance log on my new 2011 says to change the oil and filter at 5,000 miles. Also, not sure if this has been brought up yet, but I was told somewhere that my truck has a specific oil with certain additional additives to assist in the break-in. Therefore, I didn't change my oil after the first 500 miles like I've done in the past on my car and motorcycles.
  10. Apr 15, 2011 at 10:09 AM
    #50
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    I heard from the dealer they switched to synthetic for '11 Tacomas and so this is the new interval. The synthentic oil probably will last that long with no problems, but the filter won't. My BMW I had before had 15,000 scheduled oil changes, which was ridiculous. I always changed the filters after 5 to 6k miles because I knew they wouldn't go 15k.
  11. Apr 15, 2011 at 10:19 AM
    #51
    GetBarelled
    GetBarelled √ Back in a Taco again √
    SF Bay
    06 TRD OR 4x4
    Billy 5100's all around. Otherwise, the truck is OLD and STOCK.
    Sold my 97 4x4 Tacoma 5-speed at 267,000 miles, and it would still pull like a champ. Used dino and changed every 3-5k miles. Never had an engine problem. Probably should've just held on to it.
    If you want to take care of your truck, don't let it go over 5k between oil changes, regardless of what the manual or dealer says.
  12. Apr 15, 2011 at 10:25 AM
    #52
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I do mine every seven thousand, works great for me
  13. Apr 15, 2011 at 10:32 AM
    #53
    buddywh1
    Philly PA
    07 DC SR5 4x4
    No doubts about that... dino is very good oil and will do the job. I do, however, like that I can get that same performance with synthetic oil but at 10k OCI's. Maybe even more but that's quite good enough.
    And my other point is: no vehicle is fun at 267K miles unless you also enjoy fixing things regularly. I get rid of mine at about 10-13 years, 130-150K miles just because of the accumulation of niggling things from blinker switches and seat springs to not-so-niggling things like A/C compressors, suspension bushings and fuel pumps that go bad.
  14. Apr 15, 2011 at 11:09 AM
    #54
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    A lot of people who have high mileage vehicles, put the mileage on very quickly. There's a huge difference between a 5 year old vehicle with 100k and a 10 year old vehicle with 100k. The 5 year old vehicle could still appear practically new, while the 10 year old vehicle could be beat to hell and worn by the elements for an additional 5 years.
    Personally, I'll be at 100k in 4-5 years, and my truck will still look new. I plan to keep it for as long as I can...I would love to break 300k.
  15. Apr 15, 2011 at 2:16 PM
    #55
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    If you changed your oil @10,000 miles using synthetic vs dino @ 5,000 it seems like a wash $$ wise unless we can prove synthetic is better for the motor. But if you went in to the Dealer with an engine issue with the practice of using synthetic and changing @ 10,000 miles, and had all the service records, your claim may be denied because the manual states 5,000 miles/6 mo, for oil changes, with no exception of synthetic oil use and extended miles/periods stated. However, "tests" and many agree synthetics do last longer or do not break down like dino. All I know is as many have mentioned, this a small part of maintaining a vehicle, but when I change my dino oil between 4-4500 or less miles, it always looks "tan" or not worn out. :D
  16. Apr 15, 2011 at 3:01 PM
    #56
    buddywh1
    Philly PA
    07 DC SR5 4x4
  17. Apr 15, 2011 at 7:29 PM
    #57
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Lastly: I know you should NEVER go by looks of oil! Looks tell you NOTHING. The story of oil aging is in mechanical properties (film strength and viscosity) and it's chemical properties (TBN, or ability to deal with acids) primarily. So, I don't care about how dark it gets in use! Diesel oil can be tar-black within 500 miles of going in service: it's still perfectly doing it's job protecting the engine!
    WRONG- there are many things oils can tell us by their "off color looks", ie water in the oil, etc. way before a lab can check on the above properties.
    Plus, who was discussing Diesels?
  18. Apr 15, 2011 at 10:06 PM
    #58
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    I hear the synthetic oil is easily good for 10k, but the filter should still be changed at 5k. Hell I change mine every 6 months, eventhough I only drive 5k miles a year. But that's because the manual on the V6 says change it every 5k or 6 months .. whichever comes first .. to stay in warranty.
  19. Apr 16, 2011 at 1:34 AM
    #59
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    You have a 4.0 - if you had a 2.7 you'd have to get under it to get at the filter and have oil run down your arm - after that changing the oil is no big deal - U R under there anyway - U have done the hard part so Y not ?
  20. Apr 16, 2011 at 3:38 AM
    #60
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    My dealer told me this also, But when I saw an advertisement for this the tacoma was not listed. I would make them show you printing where it says tacoma.
