No oil change with lifetime oil changes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Montanawildlives, Oct 25, 2022.
  1. Oct 25, 2022 at 10:02 AM
    Montanawildlives
    Montanawildlives [OP] Well-Known Member
    2022 TRD off road coming soon
    Just had my first Toyota Care appointment (6 month old 2022 off-road) and it looks like they only rotated the tires, topped off the fluids, and did the multi-point inspection. But, I had purchased the lifetime oil changes, 2 per year. When I made the appointment I asked for tire rotation and oil change (and a safety recall).
    So, I suppose somewhere in the fine print it says that even if you get the lifetime oil changes, 2 per year, that you don't get an oil change if you are still under the Toyota Care period (since it provides the first oil change at 10K)? If so, really?!?
    cryptolime likes this.
  2. Oct 25, 2022 at 10:04 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I bet the answer is in the contract you signed. But toyota says 10k oil changes on our trucks, so they are going to go off that.
  3. Oct 25, 2022 at 10:05 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    First service under 10,000 miles doesn't include an oil change. Second service at or above 10,000 miles includes an oil change. Some dealerships will do the oil change on the first service depending on the service advisor.
    Big tall dave and GarlicFarts like this.
  4. Oct 25, 2022 at 10:07 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Sounds correct, first service tire rotation under 10k. 10k first oil change. Your not going to get any more free oil changes other than the recommended 10k intervals from Toyota unless you pay.
  5. Oct 25, 2022 at 10:14 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There has to be a caveat, something like 10k miles or 1 year which ever comes first.
  6. Oct 25, 2022 at 10:15 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Change your oil and rotate your tires yourself.
    Or go to the dealer and have some high school drug addicted drop-out put his greasy hands all over your truck.
    Their basic techs are a bunch of idiots, forgetting to tighten the wheel lugs, put oil back in the motor, and hotrod on a test drive.
    Good luck with your truck.
    bigoldbeef, Vmax540, whatstcp and 6 others like this.
  7. Oct 25, 2022 at 10:18 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Lifetime oil changes? Who's lifetime?
    zoo truck and AxisCab like this.
  8. Oct 25, 2022 at 10:21 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    My dealer didn't tell me about lifetime oil change but I had 2 year Toyota Care.. They changed oil, rotate tires, etc for free during 2 years... No problem.
    Some dealers have those... Mine doesn't.. I think dealerships in Georgia have them. Not sure who else have them.
  9. Oct 25, 2022 at 10:28 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    As someone stated previously, read the maintenance plan contract you purchased. I'm sure lifetime isn't the same as unlimited. They probably follow the factory maintenance schedule, which is every 10,000 miles for oil. Every 5,000 is what you got for the first one.
  10. Oct 25, 2022 at 10:30 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    10,000 miles or what amount of time? At the rate i drive it would take me 5 years to get to 10,000 miles (2007... just passed 34,000.) I change mine out every 1,000 miles which come out to around 6-8 months... even then the oil (Mobile One) is pitch black from short trips/towing.
    mquibble likes this.
  11. Oct 25, 2022 at 10:31 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    It's 5k or 6 months
  12. Oct 25, 2022 at 10:34 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You forgot they also over-tighten the oil filter housing and strip the skid plate bolts.
  13. Oct 25, 2022 at 10:50 AM
    OffroadToy
  14. Oct 25, 2022 at 10:54 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Only a few dealers in at least in my county offer a lifetime oil and filter program. It says right on Toyota you can choose 2 per year.
    edit: the caveat is it also says per manufacture schedule. That means you would need to tell them to use the special operating condition schedule, because if not, they will just do the 10k oil service.
  15. Oct 25, 2022 at 10:57 AM
    shakerhood
    Southern Ohio
  16. Oct 25, 2022 at 11:08 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Show us on the doll, where the bad man touched you.
    Stg246, Lawfarin and SWPA Tacoma like this.
  17. Oct 25, 2022 at 11:10 AM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    stop it
  18. Oct 25, 2022 at 11:19 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I change my own oil. I always remember to put the filter element in the housing.
    https://www.tacomaworld.com/threads/no-oil-filter.748693/
    Mully[QUOTED] likes this.
  19. Oct 25, 2022 at 11:42 AM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    I'm do my first service in about a month..
    They will change my oil!!!!
    I'm not going 10,000 miles on any oil!!!
    OffroadToy likes this.
  20. Oct 25, 2022 at 11:44 AM
    T.BROCK
    NorthEast Tennessee
    Salesman told me I get 2 oil changes in 2 years...guess I'm paying for it after my 1st year!!!!
