No Oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gerry ruelas, May 21, 2025.
  1. May 21, 2025 at 2:58 PM
    gerry ruelas
    gerry ruelas [OP] New Member
    Gerardo
    red 2018 tacoma TRD Sport
    I decided to, change the oil myself for the firs time on my 2018 Tacoma TRD Sport. (all previous oil changes have been done at the Dealer) when I went to remove the drain plug on the oil filter canister, very little oil came out. I removed the oil filter and to my surprise the inside of the canister and filter had close to zero oil. the filter seemed damp not full of oil. I proceeded to drain the oil pan. Maybe 1 qt of oil came out. This puzzled me, I decided to pour new oil in to see if it would come out from the drain hole. I poured close to 5 quartz and no oil drained from the drain whole. has anybody else have this issue. any Ideas?
  2. May 21, 2025 at 3:01 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Did you drain your transmission by mistake? Wouldn't be the first time.
  3. May 21, 2025 at 3:03 PM
    gerry ruelas
    Gerardo
    Pretty sure it was the engine Oil pan.
  4. May 21, 2025 at 3:04 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yeah, I think you removed the wrong sump plug brother! If the oil sump plug was actually removed and you poured 5 quarts of oil into the engine, your garage floor would be a sea of oil!
  5. May 21, 2025 at 3:12 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    If it was the transmission, about 3 quarts of fluid should have come out (and it would be tinted red). So if OP drained the tranny, most likely would be very apparent on both counts…
  6. May 21, 2025 at 3:13 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Definitely don't drive it. Post up a pic of what drain plug you took off and where you filled the oil.
  7. May 21, 2025 at 3:16 PM
    gerry ruelas
    Gerardo
    Ok, after further inspection, it was the wrong plug. Thanks to everyone.
  8. May 21, 2025 at 3:17 PM
    airforceb2cc
    Don
    KCMO
    Hopefully you drained your front diff and not the trans!
    BlackTRD4Me, Jeffch and Hook78 like this.
  9. May 21, 2025 at 3:18 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    If you drained the tranny and only one quart came out, that’s not good.
    And as previously stated, not sure how you got 5 additional quarts of oil into your engine.
    Popcorn time
    wilcam47 and 23MGM like this.
  10. May 21, 2025 at 3:24 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  11. May 21, 2025 at 3:29 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    whelp, probably wont see this guy again.
  12. May 21, 2025 at 3:34 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    :popcorn:
    23MGM likes this.
  13. May 21, 2025 at 3:35 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Even if you drained the wrong pan, I’m confused on why the oil filter housing was near empty.
  14. May 21, 2025 at 3:38 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    ooops
  15. May 21, 2025 at 3:41 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    part out or trade it in on a new one, it's trashed.
    lastcall190, t0p_d0g and 23MGM like this.
  16. May 21, 2025 at 3:42 PM
    auskip07
    Skip
    Atlanta, Ga
    wilcam47 likes this.
  17. May 21, 2025 at 3:48 PM
    Buck Henry
    Yeah, I had the same thought. At first I was thinking he had just removed the filter cartridge and had a rookie concern with the small amount of oil in it (which is always the case). But he said that the filter cartridge inside was pretty much bone dry versus soaked with oil as it should be.
    I weep for this brother's truck!
    auskip07 likes this.
  18. May 21, 2025 at 4:08 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Me wonders about your brain power calling a drain hole...whole. maybe you should stay away from technical things there wilbur...
    Shawgf2000, wilcam47 and Jakerou like this.
  19. May 21, 2025 at 4:33 PM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    Just guessing here but if OP removed the overfill plug on the transmission a quart of transmission fluid could come out since the AT wasn’t pumping fluid with the engine switched off.
  20. May 21, 2025 at 4:35 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    This is incorrect.
