no pipes/straight pipe does damage???
Discussion in 'Performance and Tuning' started by AirForceTacoma08, Feb 1, 2013.
  1. Feb 1, 2013 at 5:15 PM
    AirForceTacoma08
    AirForceTacoma08 [OP] Well-Known Member
    Adan
    From AZ but Utah living
    08 Taco DCSB
    URD CAI throttle body spacer doug thorley headers straight pipes magnalow muffler URD MAF Sensor Calibrator
    i have heard mixed things about having no pipes or straight pipes could be damaging to your tacoma? i know it is illegal i'm just wondering if it does do damage or not and if i will smell the exhaust in the cab or not if i go no pipes :confused:
  2. Feb 1, 2013 at 5:26 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    straight pipes may need to worry about scavanging iirc.
    NO pipes, like open headers u may have to worry about it sounding like ass (plus scavanging).....theres u tube vids.
    happy meduim MAY BE an electric exhaust cutout but iirc u may have to worry about valves
    in short, what are u trying to do?
    make it deeper, raspier, or looking for HP?
    gotta be careful with newer engines.....sometimes the smallest tweaks can LOSE hp
  3. Feb 1, 2013 at 6:08 PM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    As Justus suggests, a good place to start might be to learn what it is you are trying to do.
  4. Feb 1, 2013 at 6:11 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    your engine needs back pressure, dont straight pipe, or cut it off. spend the money on a nice exhaust. im happy with the TRD exhaust, but didnt want something obnoxious sounding.
  5. Feb 1, 2013 at 6:14 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  6. Feb 1, 2013 at 6:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I miss the days when 4x4 was unemployed.
    He always posted such intelligent and useful information.
    Now he just..... :rolleyes:
    OP, remove the headers, start the engine, and you'll warp your exhaust valves.
    That's the only "damage" that you would do.
    With open headers or open pipes, it'll run great wide open, high RPM, but your bottom end is going to suffer.
  7. Feb 2, 2013 at 6:24 AM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    im trying to get a more deeper throttle sound and im gonna buy doug thorley long tube headers and i wanted to just have open headers. i have also been told that that whole back pressure/exhaust valve warp wont happen with long tubes.
    i've heard about the whole back pressure and exhaust valve warp thing i just dont understand how that would happen with just the headers being open. but i can understand it happening with no headers at all.
  8. Feb 2, 2013 at 6:42 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    open up the silencer on the intake and it will make serious noise
  9. Feb 2, 2013 at 6:58 AM
    Rackster
    Kevin
    Connecticut
    If throttle sound is what you are after, I'll second the response on the intake. My understanding is that the aftermarket CAIs account for the sound some enthusiasts are after. Headers should improve flow over the stock exhaust in that it should be better tuned and smoother. Depending on if you are after higher/lower torque the diameter of your exhaust will figure in. Catalytic converters are important for a number of reasons, required by law, and as noted above, running open headers (or having and improper exhaust system) can be dangerous (or lethal).
    Sounds like your in the early stages of planning your exhaust system, so do your research and ask clarifying questions. There is an optimal solution for you out there.
  10. Feb 2, 2013 at 7:00 AM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    lol i figured the ticket would come soon after i dont plan on having open headers for long just until i get the enough money for the exhaust which should jus be a couple months. but the exhaust really still get in the cab with long tube headers open like that
  11. Feb 2, 2013 at 7:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Shoudlnt hurt the valves, but power would suffer greatly, as there would be no scavenging affect.
  12. Feb 2, 2013 at 7:08 AM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    the exhaust i've heard that helps with the deeper throttle sound is flowmaster american thunder. i've seen vids of it on tacomas and it sounds great especially with aftermarket headers
  13. Feb 2, 2013 at 7:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It gives a deeper sound, but it causes a loss of about 5 HP. Small, baffled mufflers rob hp/torque, as they mess up the scavenging of the engine.
  14. Feb 2, 2013 at 7:14 AM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    so the american thunder isnt good then?? what exhaust do u recommend??
  15. Feb 2, 2013 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Youre not gonna get a ton pf power from any exhaust, and you might not notice the loss with the Flowmaster. Most flow thru mufflers, like Jardine, magnaflow, Borla, etc, give between a 5 and 8 hp gain. My thoughts are, Get what you think sounds the best to your ears.
  16. Feb 2, 2013 at 7:20 AM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    lol good info thnx good looking out
  17. Feb 2, 2013 at 7:39 AM
    Rackster
    Kevin
    Connecticut
    Different types of mufflers use different technology to cancel engine sound. What you want to find is one that absorbs the sound but doesn't restrict the flow. As Chris points out, find the one that sounds right to you and then make sure that you don't select a restrictive exhaust that cancels the sound, but detracts from your HP.
    Some of the things you'll note in Chris's writeup are that you are after a smooth, but controlled elimination of exhaust. Some backpressure is needed to give cadence to the flow which causes the syphoning action. Keeping the exhaust hot/warm throughout elimination is important as well, so pipe diameter is critical especially where you are trying to develop your power band. The key is finding an 'optimal' solution (not too big, not too small). Folks tend to 'maximize' solutions which as pointed out, can rob you of power and performance. Many folks find this out....too late.
    So do the research. Good luck!!
  18. Feb 2, 2013 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    back pressure is a bad thing in any exhaust.
  19. Feb 2, 2013 at 9:42 AM
    Rackster
    Kevin
    Connecticut
    It's my understanding that having some backpressure (e.g. cat restriction) causes the pulses of exhaust to blend, improve flow (syphoning), and low end torque. Is this incorrect?
  20. Feb 2, 2013 at 10:22 AM
    UNDEAD1153
    UNDEAD1153 Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    I know I may get flamed for this but I'm running all 4 cats and no muffler with a custom Y-pipe out to dual 3.5" tips. Sounds good in my, and my friends opinions. Just got it routed to duals yesterday so I'm hoping once it breaks in a little it'll get deeper in tone. My buddy has a 2001 v6 Tacoma with no muffler ran out before the rear tire and it honestly sounds like a small v8. I love it, as well as most people that hear it. His is pretty loud while mine on the other hand is not loud at all (IMO). I felt a loss of HP at first but now it seems to have gained it back. If you want to see what it sounds like no muffler, just unbolt it at the cat back flange. It's fairly loud with it exiting under the truck but when you exit it anywhere else, it's not that loud in the cab at all. Let me know if you have any questions. :thumbsup:
