No power after 2nd gear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lucas450r, Feb 2, 2013.
  1. Feb 2, 2013 at 4:14 AM
    lucas450r
    lucas450r [OP] Member
    Indiana
    Deer Hauler
    I have a 1997 tacoma and yesterday coming home from work when i shifted into 3rd i didnt even have enough power to get through the gear. After i got it home i replaced the fuel filter but the problem still exist. There is just barely any power in 3rd gear and up. It idles and starts fine. It has no cat so that cant be clogged. Any advice?
  2. Feb 2, 2013 at 4:56 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Vacuum line leaks, dirty maf, clogged something?
    It would help if you told us how many miles and what engine /tranny.
    Maybe you came from owning a faster vehicle.
  3. Feb 2, 2013 at 5:42 AM
    allen1992
    allen1992 Active Member
    allen
    Zephyrhills, Florida
    99 sr5 lifted
    Halo projector headlights, 30,000k HID kit, k&n intake, 3 inch rough country suspension lift, bilstein 5100 shocks, custom audio system, 33x12.50 R15 nitto's, horn blasters train horns, cut out fender flairs, magnaflow dual exhaust
    i have a 1999 and my truck started to do the same thing and i replaced to plugs and wires and it fixed to problem for. Dont know if thats what is wrong with yours but it could be possibility. Good luck
  4. Feb 2, 2013 at 6:22 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    If it was raining when this was going on I would certainly look into the plug wires possibility. But normally those deteriorate pretty slowly so it wouldn't suddenly be noticed as zero power. Unless they are arcing, which seems to happen a lot more in the wet. 20 years ago I was having trouble with power in the rain on my 82 pickup. Opened the hood at night in the rain and it was like a fireworks show. But it could be lots of things. Massive vacuum leak, weak fuel pump, ignition issues, ecu, tps, afm, could be anything. If the check engine light is on reading the codes could point you in the right direction. Of course with no cat it's probably on all the time anyhow so you're used to seeing it.
  5. Feb 2, 2013 at 6:41 AM
    lucas450r
    Indiana
    Deer Hauler
    Its a 4cyl with 155,000. I replaced plugs and wires about 6000 miles ago. I had sprayed the truck down to get the salt off from the snow but i didnt spray the engine compartment
