No power, no codes
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97tacomaguy, Sep 19, 2019.
  1. Sep 19, 2019 at 1:41 PM
    97tacomaguy
    97tacomaguy [OP] Member
    K&N air filter (tube)
    1997 - 4x4 3.4 Liter - Manual transmission
    I was having issues with acceleration going uphill. The RPMs were going up but no power. I read different things on the forum that could possibly cause it. I have:
    - Cleaned the MAF sensor using MAF sensor cleaner - no change in performance
    - Changed the spark plugs and new wires (needed it anyway)
    - Checked the PVC valve - looks good and suction in the hose
    - Changed the fuel filter
    Still no change...
    Engine runs fine, no rough idle
    - Cleaned the MAF sensor again; This time i drove it around for 45 mins. At first it seamed like it may be a little better but got worse as i drove. Heading back home i had to stop at a light. When it was time to go i put it in first get and the truck would bearly move. I slowly rolled it into a parking lot. Let it sit for about 10 mins and started it again. Again a tremendous loss of power but was able to make it home at about 25-30 mph.
    - I have a new MAF sensor being delivered and i'm also about to clean the catalytic converter.
    Any other ideas? It shifts fine with no slipping so i don't think it's anything with the transmission.
  2. Sep 19, 2019 at 2:10 PM
    eon_blue
    Azusa, CA
    I might be wrong but it sounds like a clutch issue? If your RPMs are going up but it's not accelerating accordingly it sounds like a slipping clutch to me. Which also would explain why there is no code or check engine light, since there isn't one for a bad clutch.
    How many miles on the clutch?
  3. Sep 19, 2019 at 2:12 PM
    eon_blue
    Azusa, CA
    Copied this from a google link on clutch issues..
    1. My Car Moves Slowly but My Engine Races
    This is known as clutch slippage. As you release the clutch pedal and accelerate, the vehicle moves slowly while the engine races, usually in high gear.
    Slipping is common when a clutch disc is worn out. With the friction material almost worn away, the clutch disc has less surface with which to grip the flywheel and pressure plate, making it hard for the engine to transfer rotating power to the transmission.
    Another symptom you'll notice is the clutch releasing sooner, without much pressure on the clutch pedal.
    But there are other common causes for a slipping clutch, besides a worn-out disc:
    • Clutch linkage in need of adjustment
    • Clutch linkage or cable binding (cable housing filled with rust)
    • Clutch linkage bent, misaligned, or damaged
    • Blocked master cylinder compensation port
    • Pressure plate weakened or warped
    • Clutch assembly contaminated with oil (because an engine or transmission oil seal is leaking)
    • Broken motor mount
  4. Sep 19, 2019 at 2:15 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    As stated above, my money’s on clutch...
  5. Sep 19, 2019 at 3:00 PM
    97tacomaguy
    202k miles on clutch.
  6. Sep 19, 2019 at 3:02 PM
    eon_blue
    Azusa, CA
    Definitely gotta be the clutch then, most people are lucky to get that many miles out of one. I think ~150k is usually the average, really depends on how the truck is used though (street only, offroading, towing, mostly highway, etc.)
    But at 202k I would imagine it's nearing the end of it's life and that's why it's slipping now
  7. Sep 19, 2019 at 3:03 PM
    97tacomaguy
    I've had no issues changing gears.
  8. Sep 19, 2019 at 3:05 PM
    eon_blue
    Azusa, CA
    That usually starts happening when it's really worn out, but not always. Slipping is generally the tell tale sign of a clutch going bad. If you have trouble going in-between gears but no slipping, then it's likely the shifter seat bushing. Or maybe bad synchros (not good). But just slipping = bad clutch unless there's another reason for it.
    I've had a clutch start slipping before on me when I was offroading in the mud, got some mud up in there and caused it to slip but it went away after a short while.
  9. Sep 19, 2019 at 3:05 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    It sounds like a clutch
  10. Sep 19, 2019 at 3:12 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If RPM is going up and speed is going up accordingly, then I don't think its the clutch.
    Usually they slip more in the higher gears if indeed it is the clutch.
  11. Sep 19, 2019 at 3:13 PM
    eon_blue
    Azusa, CA
    If I understand his original post correctly, he's saying the RPMs are going up but the truck speed isn't (feels like it has no power)
    Sorta like it's stuck in neutral even though it isn't
  12. Sep 19, 2019 at 3:14 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    He said no slipping. I read the first part as it was accelerating just a lot slower than normal. If the RPMs always stay proportional to speed in a given gear then there's no slipping.
    If there are no codes it might be worth watching the live OBD data while driving to see if anything is unusual.
  13. Sep 19, 2019 at 3:15 PM
    0xDEADBEEF
    I read it as it's not slipping, but stepping on the gas doesn't give you any acceleration.
  14. Sep 19, 2019 at 3:18 PM
    eon_blue
    Azusa, CA
    Would be weird to not have any codes if it's losing power that dramatically but I guess it's possible, might be a pending code stored
    He mentioned something about the cats, when I had the P0420 code for a bad rear cat I had a similar issue where it eventually felt like the truck's performance was greatly hindered. Acceleration didn't really feel like the issue more just overall 'pep' if you will. But I definitely had the code for it
  15. Sep 19, 2019 at 3:18 PM
    97tacomaguy
    "...Sorta like it's stuck in neutral even though it isn't"
    Right. And it's been gradual over the last 8-10k but got alot worse after i cleaned the MAF
  16. Sep 19, 2019 at 3:20 PM
    eon_blue
    Azusa, CA
    Have you scanned for codes to see if maybe there's a pending code stored in the ECU?
  17. Sep 19, 2019 at 3:24 PM
    97tacomaguy
    No stored or pending codes
  18. Sep 19, 2019 at 3:29 PM
    0xDEADBEEF
    Codes are mostly emissions related, so if it doesn't sense an emissions issue, it won't send a check engine light.
    If cleaning the MAF helped temporarily, that seems like a place to start. Make sure your air filter is good and if it's an oil type, that it's not over oiled.
  19. Sep 19, 2019 at 3:33 PM
    eon_blue
    Azusa, CA
    I would clean the throttle body too, gets gunked up over time although it would be pretty severe to cause what you're describing. But I could see that not throwing any codes
    Best way is to take it apart and clean it by hand, butterfly valve and all
  20. Sep 19, 2019 at 3:46 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    A bad MAF, vacuum leak, or fuel pressure problem would eventually throw a lean code I would think.
    Good point about restricted intake air flow. If it just couldn't get enough air the ECU could still keep the air/fuel ratio correct. You'd just have no power.
