No power, no codes
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97tacomaguy, Sep 19, 2019.
  1. Sep 19, 2019 at 6:40 PM
    #41
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Listen to the little bird...
  2. Sep 19, 2019 at 6:55 PM
    #42
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    It's easy to test if the clutch is slipping. In a particular gear the speed and rpm should always be proportional whether you let off the gas or floor it. For example, in 5th gear, maybe
    2000rpm ~ 40mph,
    2500rpm ~ 50mph,
    3000rpm ~ 60mph
    If you don't have a tachometer use the live data from an OBD reader to see rpm.
  3. Sep 22, 2019 at 3:23 PM
    #43
    97tacomaguy
    97tacomaguy [OP] Member
    K&N air filter (tube)
    Did a quick test regarding the clutch that someone suggested. From a standstill i put it in 4th gear and slowly let out the clutch and it didn't kill the engine. I was hoping this wouldn't be the case. Not something I'm setup to do on my own either. Will have to start calling and getting quotes. I know i'm on borrowed time with 202k on the same clutch but just after having a parked SUV totaled by a drunk driving, having another vehicle with a major issue isn't something i was wanting to deal with.
    DrZ likes this.
  4. Sep 22, 2019 at 3:41 PM
    #44
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Test for slipping clutch. Get truck moving about 15-20 mph, shift into top gear, plant the throttle. If your RPM jumps up it’ll be pretty obvious the clutch is slipping.
    If not clutch, I would think possibly catalytic converter (if part of the media is broken up it could cause one Hell of an exhaust restriction) or possibly primary O2 sensor (doesn’t have to throw your A/F ratio off that far to cause a lower loss.)
    Rachelsdaddy likes this.
  5. Sep 22, 2019 at 3:44 PM
    #45
    eon_blue
    Azusa, CA
    Sorry to hear, hopefully you can find someone local with a decent labor rate to do the job.
  6. Sep 23, 2019 at 4:41 AM
    #46
    Rachelsdaddy
    Southern NH
    Or, back the truck up till it’s touching a large tree. See if it stalls or you smell it. I don’t believe your clutch is bad. You have been driving a standard long enough to be able to determine that. If you have a scanner, report back w/ LTFT at a steady cruise.
  7. Sep 23, 2019 at 4:55 AM
    #47
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Does the truck run well cold and act up when it gets hot?
  8. Sep 23, 2019 at 9:39 AM
    #48
    eon_blue
    Azusa, CA
    He just posted yesterday he confirmed it was the clutch.
  9. Sep 25, 2019 at 7:10 PM
    #49
    Clearwater Bill
    Billy
    Largo Florida
    nice to know the internet diagnostic skills are somewhat intact............ :D
    Kevins60 likes this.
  10. Nov 22, 2019 at 10:25 PM
    #50
    97tacomaguy
    Well, finally got around to taking the truck in. It was the clutch. It's incredible how different it feels. Much more responsive when letting off and acceleration is much better. One thing though. I noticed when got on the road afterward i have a slight "tight" vibration from 30-50mph. I'm wondering if they got the driveshaft out of balance. Any thoughts on that? I'm going to get underneath it in the morning and see if a driveshaft weight is missing or a loose u-joint. It's never had the vibration before.
