No power steering HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by 67tone67, Feb 20, 2011.
  1. Feb 20, 2011 at 7:02 AM
    67tone67
    67tone67 [OP] Well-Known Member
    Tony
    Fulton Ms
    04 Dbl cab TRD
    I recently replaced my rack n pinion on my tacoma and now i have no power steering at all. Ive flushed the system and bled it.... Nuthing seems to help... The pump
    Is quiet but it feels like manual steer
  2. Feb 20, 2011 at 7:14 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Recheck the placement of your hydraulic lines make sure they are in the right spot
  3. Feb 20, 2011 at 7:36 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Everuthing was put back in the same spot. I was wondering if the pump is too weak for new rack
  4. Feb 20, 2011 at 7:38 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Also i read online that a bad pressure hose mite let air in sys without leaking. Ive only replaced rack bc of leaks underneath not bc of lack of power steering
  5. Feb 20, 2011 at 7:38 AM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Why would the pump be to weak? That makes no sense. Make sure you didn't replace the high pressure side with the low pressure. Clearly you haven't hooked up something correctly.
    Double check your work.
  6. Feb 20, 2011 at 7:43 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Yeah there wouldn't be any reason your pump wouldn't work, it really sounds like you got your hoses crossed or something
  7. Feb 20, 2011 at 7:50 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    The lines are correct
  8. Feb 20, 2011 at 7:52 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    The only thing going to the rack are lines, the only thing you replaced was the rack.
    Go recheck your work...
  9. Feb 20, 2011 at 7:55 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Unless you bought a bad rack, something isn't right and the first best thing is to.............
    Recheck your work.
  10. Feb 20, 2011 at 8:03 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    I have rechecked the lines. If the rack was bad it seems like it would leak. Fluid flowing fine i bled pump again to check flow. The lines were placed in the exact spot they were removed
  11. Feb 20, 2011 at 8:06 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    The rack was purchased from Dearborn Axle.... And carries a lifetime warranty
  12. Feb 20, 2011 at 8:07 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    How did you bleed it?
  13. Feb 20, 2011 at 8:09 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Well I dunno then that's pretty much all I can think of that would cause loss of power, it all worked fine before you replaced the rack? Could it be that one of your lines are plugged?
  14. Feb 20, 2011 at 8:12 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    I cleaned the lines before install . And then i flushed system....part of warranty req
  15. Feb 20, 2011 at 8:14 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    To bleed u place return line in a puke bucket while pouring fluid in res.... While engine running until the fluid is the same color as what u pour in then replace cap and return line
  16. Feb 20, 2011 at 8:14 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Call up where you got the rack from and ask them, there's something that might have been overlooked and they might be able to tell you
  17. Feb 20, 2011 at 8:17 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    I bled air out by raising front
    Wheels removing power steer cap and turning the steering wheel from
    Lock to lock several times yesterday and again today.
  18. Feb 20, 2011 at 8:18 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Thats my next move! Thanks
  19. Feb 20, 2011 at 8:26 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Hopefully they have a solution for you, goodluck!
  20. Feb 20, 2011 at 11:06 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    No such luck. They blamed everything but the unit. Claimed air was in the system despite my bleeding it six times as instructed. So im back to square one. The steering hasnt gotton any easier and i dont see how there cud be that much air in the system to completely take all the power away
