No power to fuel pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drewboto, Aug 7, 2013.
  1. Aug 26, 2020 at 12:24 PM
    jagbayani21
    jagbayani21 Active Member
    Justin
    1995 Tacoma 3.4 V6
    SuperCharged, K&N intake, 4.88 Limited slip
    How would i check this?
  2. Aug 26, 2020 at 12:29 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Aug 26, 2020 at 12:30 PM
    tacoma4
    tacoma4 Well-Known Member
    Substitute a load for the pump. I would use a headlight bulb. Connect one side to battery positive and the other side to the fuel pump ground circuit and see if it lights up bright. You can then test the voltage difference between the ground and battery ground post.
  4. Aug 26, 2020 at 12:59 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Relay is in the area you mention
    If you have been running the pump at that low voltage quite possible it burnt up from being run under voltage.
    Gotta find the cause of the low voltage first .
  5. Aug 26, 2020 at 1:06 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is interesting My EWD does not show that relay Must have done away by 2000
  6. Aug 26, 2020 at 1:18 PM
    jagbayani21
    Justin
    1995 Tacoma 3.4 V6
    Say i did short the wires/fuse/relay. Would i need a new electrical harness from the ecu?
  7. Aug 26, 2020 at 1:25 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Only if The Fire Company showed up at that point a wiring harness is not a issue Fire Sale
    Look for melted insulation melted connectors and plugs
    If you put 12 VDC into the circuit and by passed the Circuit protection caused a short or had a short wires will be hot till one burns through and opens the circuit We would all Hope the circuit opens before the Truck catches fire.
    Best answer it is possible!!
  8. Aug 26, 2020 at 1:26 PM
    jagbayani21
    Justin
    1995 Tacoma 3.4 V6
    Sorry confused on whatbyou mean by fire sale. Are you saying the only way harness is f***ed is when it catches fire?
  9. Aug 26, 2020 at 1:28 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Close Enough
  10. Aug 27, 2020 at 10:43 AM
    Hadmatt54
    Hadmatt54 Member
    2003 Prerunner Quad Cab
    4wd conversion
    Sounds like several different problems in this thread. Fuel pumps have built in check valves so that 1) that later model Toyota engines where the circuit opening relay is controlled by the ECU will start on existing fuel pressure really before the fuel pump starts pumping. &
    2) so that fuel doesn't drain back into the tank ( fuel system loses it's prime) if the vehicle sits for any length of time. That sounds like what is happening in a couple of above mentioned problems. Lower voltage on a fuel pump will not hurt it...early Tundra's and Lexus' used resistors with a relay to slow down the rpm of the fuel pump to lower fuel pressure when the engine didn't need full pressure. Today these vehicles use a separate fuel pump ECU to control this.
    Also when troubleshooting electrical problems...broken wires can still give voltage readings, but will not carry current. For example if a wire has 12 strands, but 11 are broken, you will still get a voltage reading even though that one strand won't carry the current required by a curcuit.
  11. Aug 27, 2020 at 11:59 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    If you want to try to bypass it just to be able to drive places, there's a wire under the driver side step plate you can splice into +12V. I can take mine off for a pic if wanted
  12. Dec 14, 2020 at 12:26 PM
    jcp09
    jcp09 Member
    2004 tacoma
    Was this problem ever found? I have a 2004 3.4 that is doing the same thing. 12 volts going through the c/open relay and 4.5 volts at the pump.
  13. Dec 14, 2020 at 12:44 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  14. Mar 26, 2023 at 2:07 PM
    Slickcowan
    Slickcowan New Member
    Rick
    1997 Tacoma 2.7
    Was the problem ever found I have a 1997 Tacoma 2.7 voltage drop at the under dash relay
