No Power to OBD2 Port
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jadoiron, Mar 8, 2016.
  1. Mar 8, 2016 at 5:41 AM
    jadoiron
    jadoiron [OP] Well-Known Member
    2016 Tacoma 2x4 Access Cab Barcelona Red Metallic
    Has anyone else experienced this problem?
    I have a device that plugs into the OBD2 port (and works fine in other vehicles).
    I have a switch that I installed for my LED light bar, and I'm getting 12v power to that switch via a wire that I tapped into that's located behind the driver side panel in an UNUSED plug. Is it at all possible that this could have affected the OBD2 port!? It seems unlikely because I didn't touch anything to do with the OBD2 port, but maybe it's somehow related to the wire I snipped out of what I THOUGHT was an unused harness!?
  2. Mar 8, 2016 at 6:57 AM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Only one way to find out. Remove that tap.
    I have an elm 327 obd2 BT adapter that I keep plugged in 24x7 and it is always powered.
  3. Mar 8, 2016 at 7:06 AM
    jadoiron
    That's exactly what I have too... Will see if I can get to the bottom of this during lunch!
