No power up hills
Discussion in '1st Gen. Tacomas (1995-2004)' started by renots, Sep 19, 2014.
  1. Sep 19, 2014 at 6:14 AM
    renots
    renots [OP] 15mpgTaco just entered the chat
    Doug
    Southern Illinois
    04 Tacoma SR5 TRD OR 3.4L M/T 4x4
    OME suspension lift 882 coil overs Aftermarket UCAs and upper ball joints with zerks Arb bumper with warn winch All new dakkar leaf springs Diff drop kit Suspension parts purchased at wheelers off road 32” all terrains and nicer bullet hole rims.
    I have an 04 taco 4x4 loaded. was going up steep grades coming home from salt lake city. I was absolutely not able to accelerate up hills. I would floor it and it would still drop 1-2mph every 10 seconds. Even downshifting into 4th didnt help much. It would hover at 2500 rpms and gradually drop. This seems strange because in town I have plenty of power. I do have the 6cyl. Any thoughts, comments as to where I should start looking for problems would be appreciated. Thanks!
  2. Sep 19, 2014 at 9:55 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    sounds like a Toyota to me. Big difference in flats in the city vs.goin up hills.
  3. Sep 19, 2014 at 10:03 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Switch off overdrive.
  4. Sep 19, 2014 at 10:07 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    clogged or clogging cats?
  5. Sep 19, 2014 at 10:09 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    loaded-how much weight?
  6. Sep 19, 2014 at 10:12 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    never have a problem with hills here in TN. plenty of power. hiway and secondary roads. have you run these roads before and had power?
  7. Sep 19, 2014 at 10:13 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    altitude? 7000' above sea level?
  8. Sep 19, 2014 at 8:05 PM
    lt thistle
    lt thistle Member
    Oregon
    02 3.4L SR5 TRD
    Shift down to 3rd and give her hell
  9. Sep 19, 2014 at 8:37 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Same problem here. On slight hills and/or windy situations it won't keep up at 60/65 mph. Noticed it when I upgraded from 32x11.5 15's to one size bigger to 33's. Made that much of a difference. But since I had the truck I've noticed a slight decrease in power over time and I believe it to be my cats. Just haven't got around to that yet. Also my wheel bearings need changed. I'm sure it's a combination of those things. Mostly tires but we will see when I get all my junk replaced.
  10. Sep 19, 2014 at 8:39 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    supercharge
  11. Sep 19, 2014 at 9:35 PM
    1980 Well-Known Member
    The Dust Bowl
    I used to live in Oregon and drive back to the Midwest about six times a year. All of the Toyota pickups I've owned before my current 2nd gen were manuals and all had to be downshifted to 3rd sometime on the trip, even the turbocharged '87. The 4.0 liter 6 cyl '06 automatic is the first Toyota truck I've had that can maintain the speed limit in the mountains without much of a problem.
  12. Sep 19, 2014 at 10:17 PM
    NightProwler
    Harlan
    Maricopa, Az
    Sigh one day.. last on never ending list. You guys that have em make so fucking jealous!! Probly be on a rebuilt motor by then. But come on, v6, should be sufficient for this...
  13. Sep 19, 2014 at 10:31 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    There's a far difference between the western rockies part of the country and the east coast.
  14. Sep 22, 2014 at 4:53 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    That is why "altitude" was questioned--we are about 6.5K (highest)above sea level- lowest point 1200'-I can tell a power diference in the altitude.
  15. Sep 28, 2014 at 11:51 AM
    easttn99
    easttn99 Member
    Cody
    Cookeville, TN
    '99 Tacoma Maroon 4wd SR5
    Rhino lined bed, tool box, side steps, window tint, Flowmaster exhaust, cb radio, trailer hitch.
    I live in East Tennessee too, but I have thought for quite some time that my truck is a little underpowered when climbing hills on the highway. Even after a full tune up, it seems like it should do a little bit better. I still love my truck, and even though some of these hills are fairly steep, I have just put it off as a small truck with over 100k on it... maybe I have been missing out on the full potential of the Toyota since I got the truck if others are full of power.
