No power when key is on
Discussion in 'New Members' started by Harleyguy, Apr 20, 2015.
  1. Apr 20, 2015 at 7:16 AM
    Harleyguy
    Harleyguy [OP] Member
    Scott
    04 Tacoma sr5
    Hi I have an 04 Tacoma I have headlights some lights an door chime turn key on an I get nothing any help thanks
  2. Apr 20, 2015 at 7:19 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    low battery, is it a stick or auto?
  3. Apr 20, 2015 at 7:47 AM
    Harleyguy
    Scott
    04 Tacoma sr5
    Stick if I turn ignition on the image doesn't light up no radio or clock
  4. Apr 20, 2015 at 8:04 AM
    Halhjak
    Halhjak Questioner
    Jake
    Central Oklahoma
    White 2007 Double Cab 4x4 V6 4.0
    2 1/2 lift, Black Emblems, Red Interior LED lights w/switch
    Check The Battery. Experienced something similar on my 07 Tacoma
  5. Apr 20, 2015 at 8:08 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    first thought--BATTERY--they die quickly.
  6. Apr 20, 2015 at 8:10 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    there is enough voltage to turn on a couple things--but NOT enough to turn it over.
    Bad battery-imo
    If battery is relatively new-check connections.
  7. Apr 20, 2015 at 8:57 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    FIXED???????????????????
  8. Apr 20, 2015 at 9:05 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    As others have said it's most likely your battery. I had the exact issue the other week and a new battery fixed it. Volts were fine on the battery but I had a whopping 5CCA. It was dead.
  9. Apr 20, 2015 at 9:56 AM
    Harleyguy
    Scott
    04 Tacoma sr5
    Checked it with volt meter 13.8 even tried to jump it no luck headlights are bright turn key to acc n nothing comes on no radio lighted or even mileage comes up
  10. Apr 20, 2015 at 11:38 AM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    check fuses and then check for 12v at starter,did u try to start with truck in nautral and use the clutch cancel switch?
  11. Apr 20, 2015 at 2:52 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    does the motor "click" when you turn the key?????
    If so-that might be an indication of starter problems.
    Keep us posted--if it is the starter--there will be a follow up.
  12. Apr 20, 2015 at 3:14 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    WHERE ARE YOU??? someone may live nearby--we like to HELP!!!!
  13. Apr 20, 2015 at 5:45 PM
    Harleyguy
    Scott
    04 Tacoma sr5
    i am in pa tried new ignition n new battery no go i can make it run with jumper wire from starter to battery but i have no accesseries wipers heater turn signals radio tac stumped any ideas thanks
  14. Apr 21, 2015 at 4:20 AM
    Over da Hill
    Over da Hill "Roads...where we're going we don't need roads"
    Johnny
    SoCal
    15 Black Taco 4WD DC SB SC
    Supercharger, Icon stage 3 suspension, Pelfreybilt Armor, All-Pro Sliders & Leaf Pack, 17 inch Black Rhino Sidewinder wheels, 33 inch Toyo tires, Rigid Lighting, SPod,
    Maybe a mouse got into your wiring and chewed some of it up. It happened to my last truck and is a common occurrence according to the dealership. Keep us posted...
  15. Apr 21, 2015 at 5:02 AM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    Did u check all fuses?did u check voltage at starter when cranking?Where in PA are u?
  16. Apr 21, 2015 at 5:25 AM
    Harleyguy
    Scott
    04 Tacoma sr5
    Ya checked all fuses I'm about 60 miles north of pittsburgh
  17. Apr 21, 2015 at 6:06 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Just testing the battery with a voltmeter will not determine if it is capable of producing enough current to start an engine. The most common battery problems are low electrolyte levels for wet batteries, corroded/oxidized positive and negative (ground) terminal connections not allowing the battery to recharge, or sulfation affecting the CCA performance or capacity.
    Please see the Car and Deep Cycle Battery FAQ in www.batteryfaq.org for more information of troubleshooting, testing and remediation.
  18. Apr 21, 2015 at 2:31 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    fuse??? -not sure which one--giving you a bump--one of the master mechanics -PLEASE chime in.
    BUMP
  19. Apr 22, 2015 at 3:34 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    FIXED???????????????????????
  20. Apr 22, 2015 at 9:44 PM
    Over da Hill
    Johnny
    SoCal
    Any news?
