No pressure when removing gas cap
Discussion in 'Technical Chat' started by bleverman, Dec 28, 2014.
  1. Dec 28, 2014 at 6:42 PM
    bleverman
    bleverman [OP] Member
    I noticed this problem a while back and purchased a new gas cap from Toyota. Now 6 months later it failed inspection due to the same problem. They made me buy a new cap and passed it without checking it. Whew. How can I fix this??
  2. Jul 22, 2015 at 2:58 PM
    eco
    eco New Member
    2006 Tacoma SR5 Prerunner
    Does the tank always release pressure when taken off? I am having a gas smell with my '05 Tacoma; it smells around the gas cap. Truck not throwing codes.... bought a new gas cap from Autozone, didn't fix the problem. I was told by a mechanic that the newer vehicles don't release pressure, but I have my doubts. The way I understand it is that it should release pressure but not vapors because it passes through the canister first. When I take off the old cap and now the new one, no pressure is released. Is this normal?
  3. Jul 22, 2015 at 3:18 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Totally normal. If you pull the cap off and look inside and up there are 2 holes at the top of the fuel filler neck where pressure is vented. That's why you are supposed to keep your truck shiny side up - to prevent fuel leaks through those holes.
