No radio, clock, power ports
Discussion in '4 Cylinder' started by wgerow, Mar 20, 2010.
  1. Mar 20, 2010 at 5:25 PM
    wgerow
    wgerow [OP] Member
    I have a 02 2.7L ext cab. It is 100% original, stock everything.
    I boosted my girlfriends volvo the other day. I did not ground the booster cables. I did not hear or see anything unusual. the volvo started, everything was fine. Until I realized the next morning that my clock, radio and power ports including ligher port do not work. I checked the fuse, it was blown, replaced it. Still a no go. I have not checked every fuse in the box, but I did use the manual and suspect I replaced the right one, it was blown. So of course now i don't know what to do. Any suggestions?
    Thanks
  2. Mar 20, 2010 at 5:27 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    welcome to TW, if you didnt check all of them I would say go back and check the rest of them! and maybe check the ones under the hood as well
  3. Mar 20, 2010 at 5:29 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    welcome to TW.. i would double check the fuses.
  4. Mar 20, 2010 at 5:55 PM
    wgerow
    wgerow [OP] Member
    Thanks for the welcome.
    I check the rest of the fuses, there was a ACC fuse under the dash that was blown, I replaced it. Still no luck. There appears to be an AC power Relay in the fuse box under the hood. Any chance it is that? Any way to diagnose the relay?
    Thx
  5. Mar 20, 2010 at 11:51 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    I am nor surebro. Hope someone else has more info
  6. Mar 22, 2010 at 9:01 PM
    Wrencher86
    Wrencher86 Active Member
    Chicago, Il
    '10 4x4 5Spd Reg. Cab 4cyl.
    If there is another fuse with the same part no. on it near by (preferably for something minor, like the horn) you can swap it out and check your radio to see if it works.
    If you can get a wiring diagram for the systems that would be helpful. It might also tell you if there is a fusible link in the system somewhere. Those can be hard to track down when they burn out.
