No re-gearing for 35s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cbrunhaver, Apr 11, 2023.
  1. Apr 21, 2024 at 6:27 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm fine with the performance and trailer towing capability with factory tires (30.5"). I barely notice the difference with 265/75/16's, (31.5") and would probably find a true 33" tire acceptable. But 35's are just a bridge too far IMO. That is more performance loss than I'm willing to deal with and re-gearing is more expensive than I'm willing to pay. I spend too much time in mountains and towing.
  2. Apr 21, 2024 at 6:31 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You don’t know what you don’t know. While you may find your setup tolerable, you’d probably find a regeared setup a whole lot more tolerable. Everybody is on about better performance. If you’re happy as is then save your money and leave it be.
  3. Apr 21, 2024 at 8:37 PM
    TacoTuesday1
    SD CA
    I forget if auto is shorter or taller than manual
    and 5 speeds instead of 6
    One possible mistake I made was getting heavy ass tall skinny load E for no reason that proved to be no more puncture resistant
    instead of the standard wide 33 that might be lighter
    Maybe a lighter wheel
    standard width looks like a bigger tire than skinnies imo despite same diameter
  4. Apr 21, 2024 at 8:52 PM
    BLtheP
    Plano, TX
    He is speaking from the 3rd gen 6-speed auto which is tall as hell in the final drive.
  5. Apr 21, 2024 at 10:03 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Shots fired at the 2tr-fe guys lol i agree i had to throw 5.29s at it to make it have a little pep.
