No rear running lights…
Discussion in '2nd Gen. Tacomas (2005-2015)' started by powerw1980, Nov 1, 2021.
  1. Nov 1, 2021 at 12:03 PM
    powerw1980
    powerw1980 [OP] Member
    2005 Tacoma Prerunner
    I know that there is multiple threads on this. Nowhere have I found an answer yet though. Does anybody know why the brake lights are working but not the running lights. They are the same lightbulb. And this is new it worked just the other day I have no idea why now it’s not. I’ve checked all the fuses I have replaced the brake switch. Somebody point me in the right direction please
  2. Nov 1, 2021 at 12:07 PM
    guyfromky
    guyfromky Well-Known Member
    Have you changed the bulb? The bulbs have dual-filament so just because the brake lights work doesn't mean the tail lights do.
    Knute, powerw1980[OP] and SR-71A like this.
  3. Nov 1, 2021 at 12:11 PM
    powerw1980
    I checked the bulb. Both Filaments are good. Even change them out to be sure.
  4. Nov 1, 2021 at 12:17 PM
    guyfromky
    You need to check the socket with a multimeter and/or test light, whichever you have, and see if there is power when the tail lights are turned on. Preferably a multimeter to see if voltage is appropriate.
    powerw1980[OP] likes this.
  5. Nov 1, 2021 at 12:20 PM
    guyfromky
    Also, do the front parking lights/DRL's work?
  6. Nov 1, 2021 at 12:23 PM
    powerw1980
    I have not checked the front DRLs. Checking now
  7. Nov 1, 2021 at 12:45 PM
    powerw1980
    OK so I checked my daylight running lights on the front are not working. And I do not have voltage at the Rear lights When I turn the headlights on. But on the terminal for the brake lights I do get power when I push the break in
  8. Nov 1, 2021 at 12:54 PM
    guyfromky
    Sounds like the problem is the parking light/headlight switch then.
  9. Nov 1, 2021 at 1:06 PM
    powerw1980
    Found the problem guys. The loose ground on the driver side under the bumper. They are now working thanks for the help
    deanosaurus and TnShooter like this.
  10. Nov 2, 2021 at 4:46 AM
    guyfromky
    Good deal. Glad it's fixed.
