No running lights on trailer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jiujitsu77, Feb 19, 2023.
  1. Feb 19, 2023 at 11:17 AM
    jiujitsu77
    jiujitsu77 [OP] Well-Known Member
    ross
    lake jackson
    I have a 2015 DBSB with the 7 to 4 pin adapter for the trailer lights. its hit or miss on every light working. sometimes my turn signals make both lights flash like hazards now i have turn signals and break lights but no running lights. i hooked up both trailers to my dads tacoma and everthing works. i used a test light and have power to everything except the running lights. has anyone had this problem? if so what do i need to do?
  2. Feb 19, 2023 at 11:45 AM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Clean the Ball on your truck Really Good. Clean up inside Coupler on the trailer Really Good. Check the Ground for the lights on the Trailer and the Ground for the trailer lights on the truck.
  3. Feb 19, 2023 at 12:10 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP, did you use the same 7 to 4 pin adapter on your pop's tacoma? If so check for corrosion in your 7 pin socket. Often times ill take my 7 to 4 pin and insert/remove it a few times before final seating to scrape off any dirt/corrosion present.
    Properly wired, the trailer shouldnt even need to be hooked to the ball or be touching the truck in any way for all lights to work. Do not rely on the ball to make a good ground.
    usmc2msu, Jimmyh, E4x4 and 3 others like this.
  4. Feb 19, 2023 at 2:55 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    The Engineer in me wants to believe this statement, but 30 years working at a marina towing everything under the sun says otherwise. I've seen many properly wired truck and trailer combinations that absolutely required a good ground through the trailer ball. Why? I have absolutely no idea. Trailer light (and brake) wiring is sometimes just possessed - usually on the ground side.
    BTW, I too plug and unplug my trailer converter harness several times if I haven't used it in a while. I also Fluid Film the trailer connections on my 4Runner before winter every year.
    MARSHBUSTER and Dm93 like this.
  5. Feb 19, 2023 at 3:08 PM
    Waasheem
    Waasheem
    2007 xrunner
    Possessed ground, absolutely. I done seen the beyond absurd because of bad grounds.
    One pickle factory machine tail light was giving me fits, until I ran wires directly from the negative battery post to the tail lights.
  6. Feb 19, 2023 at 4:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When using the test light, where are grounding the light?
    There’s a few thing here that need addressed/answered.
    Do the running lights NEVER work?
    Are you using the same 7-4 pin adapter on your dads truck?
    Have you used the test light to check the ground pin?
    Not that it matters at this point, but I bought a 7-4 pin with “test” lights built in.
    It helps narrow down, truck or trailer issues.
    Similar to the one linked below. (I think mine is a Curt brand)
    https://www.amazon.com/Hopkins-47345-Wire-Flat-Adapter/dp/B0002RNSKK?smid=ATVPDKIKX0DER
    Dm93 likes this.
  7. Feb 19, 2023 at 5:05 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I've seen so many trailers that are wired incorrectly, even new ones. For some reason many trailers seem to be wired where the lights have to ground through the hitch instead of the ground being tied to the frame of the trailer, I always hook the ground directly to the trailer frame when I wire them.
    That being said the OP needs to check the Towing Tail Fuse (30A) in the underhood fuse box and if that's good then check that the corresponding pins on the truck plug have power when they are supposed to.
    TnShooter likes this.
  8. Feb 19, 2023 at 5:18 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Your first problem with one turn signal flashing both sides is a bad ground. To fix, clean the ground pins and sockets. While you're there, go ahead and clean all of the pins and sockets on the trailers and the truck. I suggest using rubbing alcohol and Q-tips. Then put silicone grease (bulb grease) on the ground pin to protect it from corrosion. While you're there, put it on all the pins. Then plug and unplug everything several times to spread the grease onto all of the pins and sockets. The grease will protect the metal from corroding and creating a bad connection.
    Also put weather covers on the trailer plugs. If either or both sides of the 7-4 adapter are left exposed to the weather while unplugged, start storing it in the cab or put weather cover(s) on it, too.
    What was said above about plugging and unplugging each plug several times when connecting a trailer is good advice.
    Now about the running lights: Do the running lights on the truck itself work? If not, fix that. If so:
    If cleaning the plugs and sockets didn't fix the trailer running lights, check the 30A Towing Tail fuse in the fuse box under the hood. If it's good, check the Towing Tail relay in the same fuse box. If I'm not mistaken, the inside of the fuse box cover shows the location of that relay. If not, put your finger on the Towing Tail fuse and move it in the direction of the Stop and OBD fuses. Keep going until your finger reaches the first relay. That relay is the Towing Tail relay.
    jiujitsu77[OP] likes this.
  9. Feb 19, 2023 at 6:50 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    some lights are self grounding, and if there is no connection (or poor connection) of your trailer chassis ground to trailer plug ground that’s the only way it’ll work.
    A lot of times, with that long of wire travel and many connections, a ground reference gets a high resistance connection so that connection to the ball can provide that little extra reduction in resistance the trailer lights need to operate.
  10. Feb 20, 2023 at 4:25 PM
    jiujitsu77
    ross
    lake jackson
    I have cleaned the pins and used dielectric grease. i have the plug with the test lights built in and the running lights on there wont come on. we tested the trailer lights on my dads with both the 7 pin adapter and with the reg 4 pin plug and eveything worked. yes the running lights on my truck work.
  11. Feb 20, 2023 at 4:27 PM
    Too Stroked
    Tom
    Time to start tracing back through the circuit to see where you lose power then. You have checked your fuses right?
    Dm93 likes this.
  12. Feb 21, 2023 at 5:06 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    I have had a similar experience - all circuits on the 4 way adaptor are good. Trailer lights were kind of intermittent, then after pulling the trailer out of my backyard, all lights worked, and worked the rest of the
    season, no rhyme or reason - trailer lighting gremlin's. I know it is a ground issue, but short of rewiring the trailer, I just tow it a short distance and everything works.
